Cam question, Elgin E-980-P
I am freshening up my old 406 for my 65 LeMans project and I am going to install a little Elgin E-980-P. It does not have a typical cam card so my question is, how can you tell how much if any advance is ground in this cam? Here are the specs:
E-980-P Details Range Part Number Direction Cam Int Valve Int Advdur Int Timdur Int Open Int Close Int Overlap Lash Int Center Int Cyl Footnote C E-980-P INT .296 .444 288° 214° -1° BTC 35° ABC 69° HYD 108° 8 EXH .311 .466 298° 224° 48° BBC -4° ATC 116° Thank you, John
Johnny US Army Retired 1978 T/A 463 Pontiac, KRE 74cc 292CFM D-ports, Lunati VooDoo, V-max lifters, TKII, ATM 850 E85 carb, TCI TH-350 race tranny, 3600 converter 3.73 12 bolt 11.63@116.68mph 1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car. 1980 Formula 350 Pontiac back burner project 1972 LeMans 350 Pontiac |
(ICL + ECL = ___ ) ÷ 2 = LSA
LSA - ICL = amount cam is advanced (108 + 116 = 224) ÷ 2 = 114 114 - 108 = 6 So the valve timing numbers tend to suggest that the cam is ground with 6° of advance. HTH Bret P. |
Thank you so much Bret, it sure does!!
Bret forgive me:
224 devided by 2 is 112 so 112 -108 = 4 4 degrees advance Rick |
That's the number my Summit 2801 was stamped with.
In my defense,it was kinda late,-and- I was posting that in a hurry. Also been so busy & hectic around here lately that I've had a hard time concentrating on much of anything,let alone keep my math straight,LOL. Oh yeah,note that it's spelled divided,not devided. BTW,as a side note to that,those valve event timing numbers are for the .050" duration. (-1° BTDC/35° ABDC/48° BBDC/-4° ATDC) Seat events for 288°/298° adv. dur. would be: (36°BTDC/72°ABDC/85° BBDC/33° ATDC). Quote:
Now you say,,,but Bret the advertised duration numbers are different between the two cams??? That's all just smoke & mirrors to make each cam co. blur the fact that it's pretty much the same exact cam that everyone else is out there selling,one co. rates theirs @ .006" per SAE (say Summit),and the next co. (say Elgin) rates theirs @ .004" or even .002" instead,as there is no real "standard" where each cam gets it's advertised duration rated at,one looks to be slightly "bigger" than the other due to the perception that it has more advertised duration than the other one has,but truth is they're the same cam. This cam: Brand & part no.: Elgin #E-980-P Grind & lobe no.: Tappet type: hydraulic Flat Tappet Spec = intake/exhaust: (notes) Adv.dur. = 288°/298° (I/E split = 10°) (Adv.dur. rated @ ???) Dur. @ .050" = 214°/224° (I/E split = 10°) Lobe lift = .296"/.311" Lift @ 1.5 rr. = .444"/.466" LSA = 112° ICL = 108° ECL = 116° Advertised/seat events: IO = 36° BTDC IC = 72° ABDC EO = 85° BBDC EC = 33° ATDC Total OL = 69° .050" events: IO = -1° BTDC (1° ABDC) IC = 35° ABDC EO = 48° BBDC EC = -4° ATDC (4° BTDC) OL @ .050" = -5° The specs I have for the Summit 2801: Brand & part no.: SUM - 2801 Grind & lobe no.: Tappet type: Hydraulic Flat Tappet Spec = intake/exhaust: (notes) Adv.dur. = 272°/282° (I/E split = 6°) (rated @ ???) Dur. @ .050" = 214°/224° (I/E split = 10°) Lobe lift = .2947"/.3100" Lift @ 1.5 rr. = .442"/.465" LSA = 112° ICL = 107° ECL = 117° Advertised/seat events: IO = 29° BTDC IC = 63° ABDC EO = 78° BBDC EC = 24° ATDC Total OL = 53° .050" events: IO = 0° ATDC IC = 34° ABDC EO = 49° BBDC EC = -5° BTDC OL @ .050" = -5° The slight difference in the .050" numbers between the two cams is purely because the Summit lists the CL's as being 107° ICL & 117° ECL. But 107 + 117 still = 224. So yeah,both are 112° LSA. Summit just lists their cam as having 5° of advance,but the odds favor that when it's degreed,it'll be exactly the same CL as the rest of those "generic" cams are at. HTH Bret P. |
Right on Bret! I always enjoy reading your posts. My 2801/980-p came in right at 107* on both the first and second try. No more regular lifters for me and will be running the hard-faced Melling JB951 from now on.
