Old 08-27-2012, 08:06 AM
PontiacMatt72's Avatar
PontiacMatt72 PontiacMatt72 is offline
Default 70 GTO Endura Bumpter bolt/stud issue
Trying to remove the brackets and metal pieces from a 70 GTO Endura bumper. some of the bolts/studs are spinning, can't get the nuts broke loose.
(1) Any tricks to get this figured out, to get the nuts broke loose and remove the brackets and whatnot?
(2) With these bolts spinning, in a "rubber" (endura) bumper, won't they just go to spinning again when I go to tighten everything back up? any fix for this?
Has anyone else ever had issues with this?
Matt
70 GTO 400 4-speed
"Turbos make no noise and leave the line like Baby Diarrhea!" - GTOGeorge
Old 08-27-2012, 09:42 AM
jmt455's Avatar
jmt455 jmt455 is offline
Here are a couple of old threads where epoxy repair is recommended:
http://forums.maxperformanceinc.com/...ht=endura+stud
I tried a lot of repair methods on my 68, but none of them worked for me. I ended up drilling a hole into the front face of the Endura bumper, removing and replacing the spinning carriage bolt and then filling the hole with flex epoxy.
Old 08-29-2012, 04:43 PM
Terry Gartner's Avatar
Terry Gartner Terry Gartner is offline
X2, I found it easier to use a cut-off wheel and cut the bolt, then replace it.
1964 GTO Auto
1970 GTO Ram Air III 4-speed
1972 Lemans Convert with endura option, 455, 4-speed
Old 08-29-2012, 05:10 PM
Forrest's Avatar
Forrest Forrest is offline
X2 here also..sorry but it's a pain!
