Old 10-06-2012, 04:39 PM
tom s tom s is offline
Default 301 stroker build
Being retired and having some time on my hands I decided to build a short deck stroker street engine.Most will ask why but my answer is why not.Turbo blocks are around and usually cheap because most dont think they make a good boat anchor.This will follow up to a post I started in the lobby as I think maybe it belongs here as my plane is to build a calif pump gas street friendly engine.I hired Dave at SD to build me a intake and do a set of heads for the small bore.He chose a E single plane intake to cut down and a set of small valve 15 heads.Plan is for 9.5 CR.He did a 2.05 intake and a CNC 260 @ 600 port job.The crank is a 63 326 unit from a doner engine from a board member.Joe Sherman of Joe Sherman Race Engines will handle the assm and dyno.We are using a BBC rod with a custom piston.The cam will be a hyd roller not yet chosen.I will post pics and tell what kind of problems through out the build.Pic of mocked up engine.Tom
Old 10-06-2012, 04:42 PM
pics of crank and main bearing area.Found we need to run a 400 thrust bearing with a 69 thou shim.All other bearing I believe will be 301 mains.Crank will be cut to BBC for the rods.Tom
ID:	299556   Click image for larger version
ID:	299557   Click image for larger version
ID:	299558   Click image for larger version
Old 10-06-2012, 04:45 PM
intake a head pics.Tom
ID:	299560   Click image for larger version
Old 10-06-2012, 04:46 PM
more mock ups.Tom
ID:	299562   Click image for larger version
ID:	299563   Click image for larger version
Old 10-06-2012, 04:48 PM
Intake from top.Tom
Old 10-06-2012, 05:05 PM
David Jones's Avatar
RPM capability?
Old 10-06-2012, 05:18 PM
David.I dont think past 6K as I cant put enough cam in it and still be street friendly.Joe Sherman said he will build it like street 383 SBC.He thought we only needed about 230 CFM heads and a cam in the 220-230 range.Dave did not have a CNC program that small.We are shooting for 425 HP which he thought was going to be easy.Tom
Old 10-06-2012, 05:50 PM
pont3 pont3 is offline
Sounds interesting, and I agree. Why not?
Old 10-06-2012, 06:16 PM
pontiac 455ho's Avatar
pontiac 455ho pontiac 455ho is offline
Send a message via Yahoo to pontiac 455ho
Very nice man that thing will sream with the standerd pontiac heads. Just remember the 301 uses its own lifter.
Old 10-06-2012, 06:32 PM
242177P's Avatar
242177P 242177P is offline
Align hone notwithstanding, would fitting a main cap from a 400 work?
Old 10-06-2012, 06:59 PM
Block web would still be too narrow.The shim is by far the best with almost no down side.The shim cant come out as there is a groove for it.Tom
Old 10-06-2012, 07:15 PM
That looks like a cool build, Tom!
Is that intake already done for the 301?
Also, which 15 heads, I figure the 1968 ones?
Old 10-06-2012, 07:19 PM
intake is done.The heads were small valve heard.Dave put a bigger valve in.Tom
Old 10-06-2012, 07:48 PM
ponjohn's Avatar
ponjohn ponjohn is offline
What final cubic inch?
Sounds like a good platform for a hair dryer.
Old 10-06-2012, 07:55 PM
gtofreek's Avatar
gtofreek gtofreek is offline
I wonder if P-Dudes shim kit for putting factory large journal cranks in 400 blocks would work with this 400 thrust bearing? It sounds like it's about the same difference in width.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
Old 10-06-2012, 07:59 PM
power adders dont work for me,I had a PM with Dude.Nunzi told me what I needed,got the material today.Taking to my machinest monday.I think we will end up 4.03 and 3.750.Tom
Old 10-06-2012, 08:18 PM
Almost 383 CID
You know, the bore of the 301 is larger than the 350, which required notches when the 2.11 valve heads were used.
Yours probably wouldn't need notches and you could use a RA IV head.
(or a RA V)
Old 10-06-2012, 09:54 PM
Joe thinks we have more than we need for 425 HP now.Tom
Old 10-06-2012, 10:37 PM
Interesting combo,Tom.
Dr. Thomas Sowell
Old 10-06-2012, 10:51 PM
Tom Vaught's Avatar
Boost Engineer
So with the cut-down intake how much was the roof of the head port raised?
Tom Vaught
