70 Judge parking lights and dash lights come on when brake pedal is pressed
Suddenly my Judge has developed this weird problem where if I mash the brake pedal the brake lights come on but so do the front parking lights and the dash lights. Any ideas what may be causing this? Thanks.
1969 GTO, RAIV, M21, 3.90, Verdoro Green/Black/Black 1970 GTO Judge, Canadian Built, RAIII, M20, 3.55, Polar White/Black 1969 Firebird, 400, TH400, 3.55, Matador Red/Parchment 2000 Trans Am, Ram-Air, WS-6, 6-Speed, Navy Blue Metallic/Black |
Any wires piching under dash by brake pedal?
1973 Formula 400 4 spd 04C build date Norwood assembly plant. |
One easy thing to check is to make sure the 4 way flasher button is not pushed in.
I've seen them with the 4 way flasher removed & switch pushed in cause that problem. |
A bad ground to the brake lights will cause this as the bulbs then try looking for ground though the parking light filament. Check where your brake lights plug into the rear panel. They ground through that connection.
GTOfreek is probably correct. A bad or loose ground will make a lot of things go weird.
It can also be something as simple as a bad parking light or tail light socket. It can connect the brake/signal circuit with the tail light circuit. OR - like my dad did once, put an 1156 bulb where an 1157 bulb belongs then have the same thing happen. The contact sits between the two socket contacts and it connects them all.
Just another "member". |
Sounds like a bad ground. Check the ground in the trunk area and make sure the brake light bulb filament is not touching the tail light bulb filament.
1971 Pontiac GT-37 Car is a junk yard dog and maybe one day will be restored. |
