small diameter brake booster
I need some ideas on a brake booster that will clear tall valve covers. 78 t/a
i'm trying to remember what mine is
i think Right Stuff? i bought the chrome i think 10" it's not the dual one, and there is PLENTY of room for my fat hands and tall moroso valve covers there was a smaller OEM size one, but my original one was the monster size and it was always a pain not sure what your budget is, but maybe a good time to look at the hydro booster setup as well since i run a somewhat radical cam with low vaccum, i use a CVR pump no problems so far |
To clear hi-ports with Morrosso valve covers and 1/2" spacer I changed to the dual booster from a 80 f/b, got it from Rock Auto.
That would be a 9" dual diaphram. They are great units, I have one on my 68.
68 Firebird, trying a q-jet now. 434/10.5:1/997's/240-242 HFT/4L80E/2800 Yank/3.42's/ Vintage Air/ 13.0 @105 mph 70 Lemans, 350/350, A/C, mostly stock 14 Ram CC, 5.7 Hemi, 8-speed, 3.92 lsd 97 Trans Am, HPP Aug 2012 http://www.highperformancepontiac.co...tiac_trans_am/ ***Sold*** |
This may be the same thing but im using a booster for a 4 wheel disk brake 79 t/a. Got it from advance auto. Its a little stronger than the '78 booster but i like it. I understand that if dont want the extra boost you can drill a new hole in the brake pedal lever to attach the booster rod to in order to reduce brake pedal leverage.
'78 Macho T/A DKM#95, 460cid, SRP pistons, KRE 310 D ports, 3" pypes, Hooker 1 3/4" headers, hydraulic roller, 10" Continental, 3.42 gears 11.5 @117.5mph 3900lbs ([_|_] ##\|/##[_|_]) |
thanks for the help!!!!!!!!!!
Does it bolt right up or are there any modifications required?
It bolts right up.
