Rebuilding a 4bbl Distributor
My 69FB Sprint distributor may need some freshening up. Nothing has been done to it for 25 years. It fires right up and seems to drive fine.
I know that a Pertronix Ign 2 is the way to go but I would also like to have the components to keep it original. I have found a list of points at NAPA but that's it. What about the springs and weights? Any need to replace them? What else do I need to restore the distributor?
69 OHC ZH Sprint Hurst 3 Speed 3:55 (1 of 213) 99 Valkyrie 1520cc Flat 6 108hp/110tq - For Sale http://sohcsix.yuku.com/forums/1/OHC-lounge Wanted: 1969 OHC "H" Camshaft |
you will see some wear on the weights as evidenced by rust/metal dust around them.
Look at the pivot pins and holes in weights to see if they are eggshaped. replace springs if you can find the correct ones.clean and grease the advance plate and have a shop with a distributor tester check the advance curve and tweak to factory specs if needed.
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
Not real hard to clean and adjust;
But if you feel it’s needing a full overhaul check around your area and see if you can locate a shop that offers the service.
I'm fortunate enough to have access to a SUN tester if needed as well as a local speed shop that offers the rebuild service for around 100$
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. Last edited by Jeff Hamlin; 04-15-2014 at 06:41 PM. |
ha brings back memories of sending my Mallory dual point out to have the points phased properly. Ill bet no one knows how to do that today.Still have that distributor too.
A good indicator on shaft and bushing wear is a dwell meter, if you watch it while changing engine speed you should not see a change in the dwell, if there is, there is wear and it should be corrected. I remember back when there were a few dual point cars around, most of the old time mechanics at the time didn't have much good to say about them....thinking the benifit was not worth the hassle on a street car.
yes each set will/should be a diff rate.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. |
this is why you need a machine to spin it up and set the timing curves to OEM.
Its not beyond to stretch or trim a spring to get the right rate.
