69 3.90 Rear P/N
What is the part number for a '69 3.90 rear? I'm looking for one with a date code suitable for a 4/9/69 build.
hsg casting # is 9795084 N for '69 A-body
Appreciate the info.
Here is a pic of the one in my first week of March '69 Judge. Center section was cast on Jan 3 (Jilian date #3 above the P/N). The assembly date on D.S. axle tube is upside down and says 057. Jilian date - 57th day of '69. If you are lookin for around Sept. 4 built car you'll need to find an assembly date on axle tube around 230 to 240 ish (Aug. guess???) and a center cast date 30 - 40 ish???? days before that. If you find a correct assembly date the center cast date should be correct unless the axle tube has been changed.
