Old 02-16-2013, 03:18 PM
GTO2nv GTO2nv is offline
Question What head gasket to use
My combo is a 482 ci. Which has a 4.250 bore and I run 14 to 1 compression with E heads on a MR-1 block,what head gasket should I use?
Old 02-16-2013, 03:27 PM
T Syron's Avatar
T Syron T Syron is offline
Cometic..
Tom Syron
Old 02-16-2013, 04:46 PM
60man's Avatar
60man 60man is offline
X-2..
But check water holes for fit..mine were off. Not sure it was the block or gaskets???
I would check to be sure..
I used a Dremel tool to "port match".
Name:	cometec match.jpg
ECM member.
MANDRA
Old 02-16-2013, 05:03 PM
Tom Vaught's Avatar
Boost Engineer
60MAN, WHOSE BLOCK?
Tom Vaught
Old 02-16-2013, 06:13 PM
Money Pit's Avatar
Money Pit Money Pit is offline
60MAN, WHOSE BLOCK?
Tom Vaught
I believe 60man runs an IAII.
Old 02-16-2013, 06:14 PM
Money Pit's Avatar
Cometic to the OP.
Old 02-16-2013, 08:50 PM
60man's Avatar
Correct...checked block with a 1016 and passages lined up. Assume Cometic had a bad stamping. ?
ECM member.
MANDRA
Old 02-16-2013, 08:59 PM
Tom Vaught's Avatar
Boost Engineer
Has happened before on some runs. When the Cometic and the 1016 line up and the block doesn't THEN you can blame the block drilling.
As was said the block was originally a dry-deck block and was converted to a wet deck so All Pontiac has no issues in this deal.
Tom Vaught
