Tri-Power Tech 57-66 Tri-Power Talk
Old 02-23-2013, 12:25 AM
franky 455's Avatar
franky 455 franky 455 is offline
Default Jet size for Tri-Power
I purchased from PY the 1966 complete Tri-Power kit and its great, but I would like to know if anyone knows what the jet sizes installed are. I'm running a 461 Butler engine kit, and I need more Fuel.
Cheers Frank
Old 02-23-2013, 12:49 AM
Old Man Taylor's Avatar
I would start with 73-68-73, but there will be some trial and error. Plus a larger than stock cam will probably require a few other changes, depending on what engine the tri-power was manufactured for.
Old 02-23-2013, 11:19 AM
Doug Doug is offline
Don't know if you use ethanol in your gas there in Aussieland but if you do, you need a notch or two larger sizes
Old 02-23-2013, 02:51 PM
66GTO Jim's Avatar
66GTO Jim 66GTO Jim is offline
Cheers Frank
Hi Frank,
To find out what jets are in the PY Tri-Power setup, I have had good luck posting questions for the PY folks in the "PY STUFF" section right above "THE LOBBY" section.
As for the upsized jets, I took Old Man Taylor's advice about 7 years ago and installed the 73-68-73 setup on my stroker engine and it was a very good starting point. I don't remember if that is what I am still running in the center because I was chasing an idle problem, a few years ago. I do know the front and rears are still 73s.
Jim
"Never try to teach a pig to sing. It's a waste of time and it annoys the pig"
Old 02-27-2013, 10:23 AM
Chris-Austria Chris-Austria is offline
I use 73-63-73 in my setup. (435cui) It depends on so much things that it's hard to say which setup will be best, you have to test it.
Bigger jets in the outer carbs are needed if you use high rpm's and have a good flowing exhaust and headers.
If they are build to original specs they might be in the range of 68-73 in the outer carbs and 60-62 in the center carb. My original 66 setup used 68-60-68.
Old 03-02-2013, 05:02 AM
franky 455's Avatar
I bought some 68s yesterday but I havent had a chance to fit them. We do have Ethanol, but I do not use it, I prefer 95 or 98 which is readily available. I'll keep you updated.
