wanted 400 engine main caps
Hello, I can buy a 74/75 400 block that is missing the main caps. If I can find some reasonable I will purchase it. It will need aline-honed but at least it will be saved. My zip code is 44481. Thanks, Ken.
It will be cheaper to buy a 74/75 400 block with the original caps than to complete your plan.
Some guys they just give up living And start dying little by little, piece by piece, Some guys come home from work and wash up, And go racin' in the street. Bruce Springsteen - Racing In The Street - 1978 |
400 main Caps
I have a couple sets if your interested. I can sell them cheap. Contact me at bradjessica@hotmail.com
Brad Pringle Wellston, Michigan 1973 SD 455 TA Auto 1974 SD455 TA 4 Spd |
Kennybill , is this block already drilled & taped for the 4 bolt caps?? If so you can buy the 4 bolt caps & have it line honed then you'll be a lot farther ahead by going that route. Plus you'll have a stronger bottom end for your project. The 4 bolt caps are only about $ 32.00 for the set. & line hone is about $ 80.00 at most shops where I'm from. You may have to pay less or more. But it will be worth it if you do.
4 bolt caps
Please let me know where to find the $32 set of main caps. I need a few of these.
I have a 74 75 400 complete. carb to pan $500 in Williamson Ny
Using caps from a different block may involve more than just an align hone at the machine shop. If there's a mismatch on the thrust bearing surface it'll run into more $$$ to correct. Unless it was an original vin block for a car I owned I wouldn't think a 2 bolt 400 block missing the main caps would be worth much. |
Thanks for the replies and the info. It was a run of the mill 2-barrel engine. I better re-think this one. I just didn't want to see it scraped. Thanks again for the replies. Ken
Brad When I typed the dollor amount it should have been $ 325.00 but the 5 must not have printed when I hit the key. I to wish I could get some for $ 32.00, but alas that won't be happening any time soon. Also Kenny Don't let it get you down , if you can get a set of 2 bolt caps they will most likly work if you have it line honed. If it doesn't line up absolutly correct it's not that big of a deal to have the thurst area ground, as there is onlt one cap that you will have to worry about & won't cost that much to get it ground so all caps meet correctly. All the Pontiac caps are very close thats why then can sell the 4 blot caps & have them work all the time with just line honeing. Don't let the last guy scare you away from a good project. When I had my 455 line honed for the 4 bolt caps for my current engine it was only out by .006. I could have put the caps on & the crank in & run it just the way it was with no problem. But don't get me wrong I wouldn't have done it without checking & have it line honed but it would have worked , so go for it & save yourself some money. Or as mentioned go for the 4 bolt caps & have a nice strong bottom end to start you project.
There you go!
Rex, I looked at that $32 and knew it had to be a typo - I don't think you can get the bolts for that.
