Horn contact pin
I need that brass springy thing which I think is a horn contact? Its for a 62 tempest but I heard other years/models might work but I dont know how to verify. So I would prefer if someone did know or actually have one from a 61-62. Kind of need it as soon as possible. thanks
Horn contact pin
I have one but if you check PY or Ames you probably could buy a new one for what you would have in a used one.
I really need one as I looked at Ames but they don't have one listed for a 62 tempest,do you know of one that will fit and how much do you want for a used one?
The pins you need , you can us the one they sell for the formula wheel & it's a trim to fit pin. They sell for about $ 7.95. Just match up the length & make it a tiny bit longer for wear over the years.
Is this trim to fit item like in a auto store?
Gary |
Contact pin should be 11/16ths of an inch long. The GM kit that PY sells is longer.
Spring in first then the contact pin. Here's the instructions lower left of the page.....
Not all the pins are 11/16th's of an inch as I ended up buying 2 pin kits from Ames because I cut mine the way they said & it was to short & didn't hit as needed so I had t buy another & fit it accordingly. But yes if you get the kit you will have to fit it but be careful when getting them from an auto parts store to make sure your getting the actual part you need, some have no idea what your talking about.
I would rather buy one from someone here that knows it will fit or where to get one from that knows it will fit,thanks
I know what you need now and will check my parts today.
Sorry, I do not have that part.
