32k Original mile 65 gp??
What are your thoughs? Steering wheel looks like it. Hope someone on the board can pick this up.
http://cedarrapids.craigslist.org/cto/3806963309.html for sale 65 pontiac grand prix 389w/auto trans appx 32k on car we belive. the car has original rebuilt 389 bored .30 over, rebilt trans, new- brakes,springs, eldebrock carb, msd dist[ original carb and dist come with car, new cooper cobra w/crager ss wheeles, dual exaust. the car will come with all the parts that i have picked up at swap meets and junk yards, 2 doors, 1 trunk lid, rear tail panel and misc. the interior is in great shape with 2 small chew holes in the headliner and a small split on side of the pass seat. the floor and trunk pans are solid w/some surface rust,the car has some rust in the lower quarter behind the wheels, it looks like the rear window leaked at one time and they sealed it up with wheather strip sealer.the next step for this car is body and paint and at this tiime i dont have the money to do it and have another project to finish, please call with questions or to see, [SORRY I CANNOT RECIEVE OR SEND TEXS AT THIS TIME]thanks for looking kevin.319-350-7401
Brad Hansen 65 Cat Ventura, 66 Cat Vert, 63 GP |
I'd say that is has more than 32000 on it.
Why would you need to bore a block with 32k miles on it .30 over?
Cut dash and console from the looks of it. Looks like a solid car for the $ though. Would have to see underside on an Iowa car before any evaluation.
"If you do everything you'll win" -LBJ 13 Smiles per Gallon: 66 Bonneville wagon 66 Bonneville 2d HT - In perpetual progress |
Yea, but the dash pad look as clean as I have seen on an AC car. From what I have seen, they tend to crack right by the vent but I agree, why would you bore .30 over on a low mile car? That steering wheel and seats look great also.
Why would you have 2 doors and a trunk for the car? guessing that there may be some rust going on??
The piping is showing through on the driver's seat too.
I have got awesome dash pads out of high miles cars.
definitely 32k original, I mean look at the air cleaner decal. (make me puke) the condition of the car based on the pics and description (bored block) I would put it at 132k.
Field of Dreams...
This seller must have the original "Field of Dreams" fever. Parked in the corn fields.
Maybe he is thinking "If I advertise it, they will come"? My own '66GP came with 100k on the odometer, NO splits in the dash, virtually perfect wheel and the engine though totally out of compression on two cylinders had NO measurable wear on either the crank or the bores. (It just had stuck rings). I rebuilt it using standard pistons and bearings. I might be unkind thinking this car has 232k on the clock but 132k might be fairer to say. Still, on his description it could be a solid project for someone to start on. Hope it finds a good home. Ian
To laugh at men of sense is the privilege of fools. |
The more I look at it the more I believe it has to be 132k and not 32k or a hard 32 at best. Should be a good project depending on frame and rust areas.
32K and the A/C compressor fell off.......
I need a better picture but the brake pedal pad looks like it has a lot of wear on the lower right corner for 32K
65 Bonneville Brougham 4DHT 65 Grand Prix 2DHT......now parts 65 Catalina 2+2 2DHT 65 Catalina Safari 4DSW |
32k or 132K, the urge to buy GP#4.....rising....
Red\black 65 Grand Prix 467 E-head stroker, Viper T-56 6-speed, 4.10 spool |
It's all downhill from Iowa dude.
32k...or 320k.
YOU be the judge! |
Thread Tools | |
Display Modes | |
