Pontiac - Race The next Level |
View Poll Results: Head porting??? | |||
I port my own heads. | 28 | 51.85% | |
I tried, but the 6X's are used as a door now or hiding in my closet. | 4 | 7.41% | |
I wouldn't know where to start. | 22 | 40.74% | |
Voters: 54. You may not vote on this poll |
Another poll
Curious with all the fast Pontiac's out, how many racers have ever ported a set of heads???
Let's hear it. Calvin Hill Hill Performance 708-250-7420 Last edited by 65nss4spdGTO; 05-30-2013 at 02:05 PM. |
I have, and damn that takes a long time by hand.
Actually Calvin, you need more options it you really want an accurate poll. I have ported Iron, and I've purchased C&C'd Aluminum.
https://www.facebook.com/Outlaw-Vint...7899333725868/ Last edited by ho428; 05-30-2013 at 02:14 PM. |
only modification needed is they were 670's and they are on the shelf....
EHTTFMF! Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead. BEING STUPID WORKS THE SAME WAY! The rest of us suffer. |
I have and I own my flow bench but just because someone can do something doesn't mean they are good at it and should be doing it.
and you know how to do a real poll. I couldnt.. CALVIN is
540 c.i. Ultra Street Combo Tiger Heads with Tiger Intake Induction Solutions fogger with .046 jet First ultra street/ultimate street NOS car to get into the 4's! 1.079 4.559 153.23. 3100 lbs 7.77 @ 169 1/4 Mile (2015) with EHTTFMF!! T2TTFMF! Special Thanks to: Ron at Rhodes Custom Auto Butler Peformance Jim Hostler's Transmissions (HOSGTO) on here Induction Solutions BES Racing Engines. Cheeseburger VP Racing Fuels Calvert Racing |
Gaby ports heads and he helps the racers.
GLTTFMF!
That's all you need to know!
First Pontiac powered street car in the 7's 7.940@170.84. 3460#s |
Little Jack and Jeff Would it be fair to call Gaby's Port the CV What. And due out soon the revised CV What Ever Port?
CVWTFEP?
Ported and cc'd. Got my burette out of the science lab at General Motors Institute.
K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 |
Plain old 6X ported with a SF110 - vehicle 4050# four door wagon, 91 octane pump gas, 3.55 gear with 28" tires, 234/244 standard hydraulic, stock geared T-400, Rhoads adjustable lifters, Q Jet, RPM, 3200 tight 10" Continental, full out the rear quiet exhaust, stage/launch at 1800, shift at 5700/5800.
One photo shows airflow (off my PT analyzer), the second shows four time slips, and there is an address for a U Tube that confirms the range of performance these heads furnish. Note that the average exhaust flow of all measurement points is about 85% of intake and has always proved to run great. Note the MPH run by this very large car. And particularly note the intake port volume average of 171 cc! Don't need huge ports when running such moderate RPM even with a 473 ci Pontiac. Max velocity in the range the engine is loaded will provide max VE! http://www.youtube.com/watch?v=LWO4G-7pwr4 car 5462 Jim Hand Last edited by Jim Hand; 05-30-2013 at 07:46 PM. |
I used Jim's book. Thanks Jim!
I've ported several pairs. It sucks.
Mike McCarty You can drop the line, but you'll never kill the spirit! Pump gas 535 w/Marcella cv/1's. 11.0 compression, 4000 stall, 3.73 gears, 275 radial, to the axle exhaust, 3470# w/driver. 9.49 @ 140..........so far |
I ported a set of small valve 17s
Retained the stock valves and got 244/168cfm Many thanks to Jim Hand's book and McCarthy's video. I swept up the shavings and had something like 2 pounds of iron. HARD work with a rotary grinder by hand. If I had it over I would have a plunge cut on the bowls. Actually did that on a set of LS3 heads and turned out great! 350CFM! So I've done 2 different families in iron and aluminum. |
What's porting ??
Anything beyond port matching I'll let the pros do... Would hate to screw up a set of $$$$$$ heads...
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
Ported some #48's myself to flow 270 cfm and ran several 10.10 quarter mile passes with them. I gained 30 or so cfm on my High Ports but then sent them to someone that has a much better idea of what they are doing. Anymore I would just buy some cnc heads that flow whatever is need.
Todd Sedlmeier Who ever thought pinewood derby cars would lead to this! October 2004 HPP Shootout participate http://www.highperformancepontiac.co...out/index.html 86 Grand Prix 535 High Port 8.93 @ 153 65 GTO 433 High Port 12.04 @ 113 |
Something's are best left to the experts that do it everyday and have proven results.
It is Like brushing and flossing your own teeth but having an expert doing dental work beyond that. |
Ported my 96's with help from Jim Hand and HO racing books/templates. Flowed 255/205. Spent many hours working, but worth it in the end for the experience and knowledge. Currently not porting a set of Kauffman D ports, 310 CNC version, I'm not going to touch them.
65 GTO, 3800#, 474, KRE Dport 330 cfm, 11:1 on pump gas, XE 242 248 solid roller, T56 trans, 3.90 gear, 11.26 @ 124 mph |
Spent 4 weekends on some 4x. Sent it off for valve and guide work and they found 1 head was cracked from the ex bowl into the ex crossover and into the void above the crossover and into the valve cover aria. If there is oil in that opening above the ex crossover you might have a problem. . Now i just pay to have the heads re-worked.
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk Last edited by Blued and Painted; 05-31-2013 at 10:23 AM. |
