Fuel pump ecctrinic
When the fuel pump ecctrinic is bolted on the front of the cam should the outer bushing turn freeley or should it be tight, when I bolt my ecctrinic on to 40lbs. the outside still free wheels thanks,------BOB
Free wheeling is good!
It should turn freely.
And while you're checking things, a camshaft endplay of .003 - .007" will verify the eccentric has been Correctly installed. Its very easy to install it wrong and end up with excessive endplay. Fwiw
'78 Macho T/A DKM#95, 460cid, SRP pistons, KRE 310 D ports, 3" pypes, Hooker 1 3/4" headers, hydraulic roller, 10" Continental, 3.42 gears 11.5 @117.5mph 3900lbs ([_|_] ##\|/##[_|_]) |
Make shure to I stall the washer with the flat side toward the cam
