Tri-Power Tech 57-66 Tri-Power Talk
Old 07-10-2013, 05:39 PM
Joel Koontz Joel Koontz is offline
Default Aluminum Tri-Power
I'm thinking about getting an Aluminum 66 Tri-Power Intake.
I already have a complete stock 66 intake, carbs etc, but the Cast Iron manifold seems to weigh about a ton.
I have not seen any threads on these lately.
Are the Aluminum Manifolds good quality?
Where can I get one, and where can I get the price on one?
Old 07-10-2013, 06:11 PM
Willshire's Avatar
Willshire Willshire is offline
I think offenhauser and edelbrock both make a 66 aluminum manifold. Ebay will give you a good idea on price. 300-500 would be my guess. I seem to recall pontiac iron manifolds to flow pretty well
It's hard to soar like an eagle, when you're surrounded by turkeys!
My wife says she'd llike my car a lot more if it wasn't mine.
64 Grand Prix 389 .030, 1.65 Scorpion Rollers, Tripower, RARE Long Branch, Custom Stainless Exhaust and mufflers, 3.90 posi 200-4R. 068 cam.
Old 07-10-2013, 06:14 PM
steve25 steve25 is offline
The Orignal parts group offers a repo 66 trip set up in aluminum and it goes for 378 bucks.
I cant say how much power it will make, but in the Sept issue of HHP mag, a near stock 65 manifold was reworked to fit the larger 66 center carb and that 432 cid motor made 473 HP.
Old 07-10-2013, 06:15 PM
Edelbrock does not offer a tri manifold any longer.
Old 07-10-2013, 07:25 PM
geeteeohguy's Avatar
I've seen photos posted on other threads of the aluminum tripower manifolds that show very poor port alignment and very poor overall quality. I would run the original manifold.
Jeff
Old 07-12-2013, 03:13 PM
Mr. P-Body Mr. P-Body is offline
We've seen at least two different versions of the aluminum repro '66 intake. We've bought 5 from Ames and all have been very nice. No re-work or welding, good fit and finish. When "porting", the typical areas the factory intake needs, the repro does, as well. JUST enough "room" for am Air IV opennings.
We've also seen two sent to us for porting by custiners, bought either on E-Bay or other "discount" house. They had significant rework and welding, including belt-sanding on the upper surfaces to remove slag. They looked pretty bad. I have no idea, the source. Avoid "bargains".
FWIW
Jim
Old 07-12-2013, 07:38 PM
Thanks for the info.
I was wondering if there was more than one supplier, or perhaps different production runs?
Old 07-12-2013, 11:33 PM
android 211 android 211 is offline
The Edelbrock and Offy tripowers were for '64 back, only. I've never seen one for '65-'66 that wasn't factory. Barry Grant made his Six Shooter 3x2 for '65 up but it used his carbs, not Rochesters.
Old 07-13-2013, 07:47 AM
chrisp chrisp is offline
Have the 1st. release repo. intake on my 64 that made 424HP. 485 torque @ the rear wheel . Have had a few from the Parts Place with poor port alignment , gasket / bolt holes are good but all ports on 1 side is shifted into the next port opening . Make sure you check your gasket to port alignment .
Old 07-13-2013, 01:23 PM
Tom Vaught's Avatar
Boost Engineer
I have a PY (1st Run) Pontiac aluminum intake that is very nice. 1st run stuff was designed and made by a different guy vs the later knock-offs, I believe.
I also have a 6-Shooter BG Intake (that will take Holley 2-bbls) that needed three runs at casting the manifold to get a good piece. Then I sent it to Mr. P-Body and Dave Wilcox to have it ported. Dave did a very nice job on the intake.
So there is a LOT of variation in the aluminum manifolds and what quality they are.
Apparently the latest AMES stuff is pretty good (rev post #6)
Tom Vaught
Old 07-13-2013, 10:18 PM
gtorich gtorich is offline
Tom Vaught
I bought this one a awhile back, think its a first run one, because of the date code, haven't installed it yet, im running a parts place one now................im sure its top notch. LOL
Rich
Name:	Andres tri power manfold.jpg
Old 07-13-2013, 11:52 PM
Tom Vaught's Avatar
Boost Engineer
I have had 2 of the early 1st runs and both were similar to what you have shown.
Tom Vaught
Old 07-14-2013, 11:00 AM
ponjohn's Avatar
ponjohn ponjohn is offline
Is there enough meat in the repop intakes get some good flow numbers?
Old 07-14-2013, 02:48 PM
Tom Vaught's Avatar
Boost Engineer
Depends on the amount of core shift. Some of the repops have a LOT.
Tom Vaught
Old 07-16-2013, 02:19 PM
What Tom said...
We'ev found the nicer ones work out nicely. There's "enough meat" to maintain the corss-sectional area when "matched" to Ram Air IV size ports. You WILL "break through" at the turns in both 7 and 8 runners at the rear... We use Moroso "A/B Epoxy" to repair the holes.
Jim
