Anyone...am aging trouble after a column swap-installed tilt. I need a schematic of the ignition switch and wiring harness as well so I can troubleshoot the non-start issue I have.
1969 Custom"S" 400 stroked to 455 Holley Dominator 870 Pontiac Performer intake KRE heads Kieth Black pistons Crane Cam Hooker ceramic coated headers CVF Racing pulley system 700r4 trans built/700hp Ford 9" 3.73 posi 4-wheel disc brakes |
Neutral safety switch? or remove the two mounting screws of your newly converted switch, leave it plugged in and leave the rod in it. push it to the start position and see if it turns over.
just an FYI!
after the column swap and all the electrical connectors swapped as well the no-start issue turned out to be the neutral safety switch-jumped it and starts right up.
Glad you found your problem.
