67 bird horn & taillight issue
NEW light harness[ only the horn is not working ] I also dI the rear harness,no lights at all there I then changed the headlight switch bingo most tail lights work except both inner tail light [the ones attatched to the green wire.still no horn,checked all fuses all look good.what should I check next
I'd say take the wheel off & check to make sure the horn contact is in good shape (cancel cam) & make sure the little spring that touchs it is good to. Then if all that is good check the horn wire going down through the coloumn.
I will check this this weekend thanks,
