My GTO came with the oil pressure line located here:
![]() The gauge seems to dance between 80 and 100 PSI (gauge could be broken). I've got a mechanical autometer oil pressure I want to use (instead of the current one) with a copper line instead of the plastic one and was just wondering if that's a good location. thanks,
1968 - Pontiac GTO |
there is a plug next to the distributor...that is the best most accurate location.
I have a guage running from both sites. seems the factory location at the oil filter sending unit reads a little higher than the hole next to dist...about 10 psi or so. |
Mine picks up to the drivers side of the distributor hole in the block.
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. ![]() |
Have mine up by the distributor also.
Jim
65 Catalina sedan. Allen Thomas Performance 495. KRE Heads at 310cfm ported by SD Performance, ProSystems Dominator carb on ported Victor intake, P-Dude custom grind hydraulic roller, MSD ignition, 3.50 Moser/Ford rear. F-Glass front bumper by son Rob, rear by the old man and joint effort for trunk lid. 3950# w/driver. Best of 9.5761/139 on 175 shot, 6.01 /114 in 1/8. |
On the filter housing is before the oil filter. Next to the dist is after the filter.
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk |
Anyone have a pic of the dist location handy? I would like to have a sender for my gauge, and a low oil pres. switch for a light/elec. choke.
George
I put the mechanical oil pressure connection at the dist hole. reads a few pounds lower than at oil
filter at warm idle.(had 17 at dist. location and 20 at oil filter when a swapped them). - Use ONLY copper type line for a mechanical gauge!!!!!! For piece of mind I put the factory type idiot light sender back in oil filter housing with stock wiring. Car has idiot lights and like all them functional as well. Gerry
1968 Firebird 400, 068 cam, TH400 & 13" Continental Converter, Auburn posi with 3:08 factory gears, Cliff's Q-jet resting on a 68 factory iron intake, DUI HEI and Ram Air pans and RARE Long Branch Manifolds |
That's where mine is, and it seems to work well. More importantly - what's with the Chevy Orange motor?
![]() Quote:
![]() The plug in front of the date code. The square socket to remove it is 5/16".
Bill 64 GTO, tube chassis w/606" IA tall deck, PG & a pro geared Fab 9". 2750 lbs. 8.2550@164.17-1/4, 5.2901@131.97-1/8, 1.1981-60-ft. 8/10/08 ![]() |
I've encountered quite a few of those engines, one very recently. I've never actually talked to someone who painted it that way to find out what their logic in thinking was... Amusingly enough all have been Pontiac 350s.
Got it that way.. painting the engine is on my list, there's just too much other things to complete first..
and thanks for the replies everyone, learned another thing about Pontiac engines today
I know what you mean, there. My car actually came with the wrong oil filter mount. (It's not angled, so the instructions for changing the oil filter include "dent the filter with a hammer so it clears the frame.") I've got the correct part, but haven't got around to it yet.
![]() Quote:
That square drive factory plug may be tight. I thought a gun had gone off when mine finally broke loose.
Thanks, Bill, I've got it now.
George
That is Pontiac Carousel red . LOL
I run off the filter adaptor on my GTO and off the block on my Grand Prix. Both have done fine but I prefer coming off of the top of the block, very accurate readings.
1971 GTO,72 400, stock bottom end, 670 heads, Lunati BMII cam, headers, iron intake Q-jet, four speed. Best 60 ft 1.806in 2004. Best 1/8th mile e.t. 8.46 with 3.55 open rear 85 Grand Prix, 70 400, casting 62 heads stock rebuild, Turbo 350 trans 78 800 cfm Q-jet modified as per Cliff Ruggles book. 87 F350 6.9 4 speed dually A poor man has poor ways. |
