Old 10-03-2013, 07:35 AM
arbys's Avatar
arbys arbys is offline
Default New garage height and lift
The wife and I are investigating another new house and garage space. I plan to put a lift in the garage and am unsure of the height needed and type of lift to be used. This will more than likely be a 4-5 car attached garage so nothing too ridiculous. Your suggestions are welcomed.
The Following User Says Thank You to arbys For This Useful Post:
Old 10-03-2013, 07:41 AM
2002Z4CSS's Avatar
10-12 foot ceiling clearance is good.
1971 Pontiac GT-37
Old 10-03-2013, 08:50 AM
The Champ's Avatar
I put scissor trusses in my 30x40 toybox with 10' sidewalls. Center height is nearly 15'. Haven't bought the lift yet, but the shop is ready for it.
Old 10-03-2013, 09:01 AM
Stuart's Avatar
Stuart Stuart is offline
Higher is better, but it depends on what kind of lift you're looking at and how tall your vehicles are. I have a four post lift in my garage and the ceiling is about 10'-6"; I can stack two cars but only if both of them are pretty low, and even then the clearances are very tight.
Old 10-03-2013, 09:13 AM
Judge273's Avatar
Judge273 Judge273 is offline
Here's my recently raised roof for a 5 car parking space garage with workshop above. Its detached at 720 sf with a 13 foot clearance to provide the max lift for car storage. Had to redo existing garage door too. Its a high lift door with side mounted door opener now.
The before picture:
Got two Eagle extended length lifts with extra height in the space.
Mike/Illinois
The Following User Says Thank You to Judge273 For This Useful Post:
Old 10-03-2013, 10:00 AM
ho428's Avatar
ho428 ho428 is offline
I have 10' and a 4 post works fine with two Firebirds, 12 would be better though.
Mike, I really, really didn't need to see that. Nice re-model.
Hmmm, I'd really like to get the RV into the garage.
Raise the roof, raise one door...
Old 10-03-2013, 07:26 PM
Cammer-6 Cammer-6 is offline
put one in like this and theres no overhead height problems
http://www.hei-lifts.com/
2 post lifts normally require 12 ft of ceiling height
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 10-03-2013, 07:30 PM
goatless's Avatar
goatless goatless is offline
I have a two post and only 9' 6" ceilings. I stack two cars in that bay, but I have to take off the wheels nearest the door on the upper car to squeeze the lower one in. It's a little tight.
1966 GTO
Old 10-03-2013, 07:39 PM
arbys's Avatar
That scissors lift scares me. Thanks for all the responses. It looks like I'm going to try to get 12' ceilings and the 4 post looks best to me at this time for possible storage. A friend has a 4 post and can move it outdoors to power wash the undersides and then move the empty lift inside.
Old 10-03-2013, 07:41 PM
Formulabruce's Avatar
I have the frost wall up 2 feet and the 8 foot wall on that, the ceiling is 14 on the edge area of the lift, and over 15 towards middle of garage. BUT I use a extra wide/high 4 post so my HD fits under my Firebird ( 1 inch to spare) and about 3-4 inches up top above the bird.. IF you ever want a truck Under a car, go 15 feet anyways IMHO the wood in my lift is a platform for doing the ceiling since when you lower a car, when wheels are slid on it, it rolls around ( LED Lighting under the ramps )
ID:	338714   Click image for larger version
The Following User Says Thank You to Formulabruce For This Useful Post:
Old 10-03-2013, 08:57 PM
Norwood's Avatar
Norwood Norwood is offline
I am so jealous
Old 10-03-2013, 09:20 PM
chrisinestes's Avatar
chrisinestes chrisinestes is offline
If my 14' ceiling was 14'4", I could stand all the way up under my pickup. I do lose about a foot because of the garage door opener, though
Chris
Cum Catapultae Proscriptae Erunt Tum Soli Proscripti Catapultas Habebunt.
Old 10-03-2013, 11:14 PM
turbo69bird's Avatar
Got to have 12ft 6 inch for a bend pak 10k
960 HP @ 11 psi, 9.70 at 146.
Old 10-04-2013, 06:50 AM
arbys's Avatar
[QUOTE=Formulabruce;5034135]I have the frost wall up 2 feet and the 8 foot wall on that, the ceiling is 14 on the edge area of the lift, and over 15 towards middle of garage. BUT I use a extra wide/high 4 post so my HD fits under my Firebird ( 1 inch to spare) and about 3-4 inches up top above the bird.. IF you ever want a truck Under a car, go 15 feet anyways IMHO the wood in my lift is a platform for doing the ceiling since when you lower a car, when wheels are slid on it, it rolls around ( LED Lighting under the ramps )
QUOTE]
What are the limitations with the four post lift other than working on the 4 tires?
Old 10-04-2013, 06:58 AM
Don 79 TA Don 79 TA is offline
[QUOTE=arbys;5034395]
QUOTE]
all depends on the work.....
at the shop the 4post was great for alignments, and keeping car loaded (exhaust work)
ours had the ability to lift the front/rear as well
way easier/fast to get on/off lift (think oil/trans fluid changes)
also a place to store tools
cons:
watch your head, it F'n hurts when you hit it on the rails
WATCH the garage height and door height too (but this applies to any lift) ESPECIALLY the antennas
two post pro:
easy to jack up just front or rear
easy for certain types of work, say suspension/brakes
Old 10-04-2013, 07:08 AM
The Champ's Avatar
Doing brakes...
But neither one is a problem if you get some 6,000-lb. capacity sliding jack platforms:
or a scissor bridge jack like this:
The Following 3 Users Say Thank You to The Champ For This Useful Post:
Old 10-04-2013, 07:18 AM
LeighP's Avatar
LeighP LeighP is offline
Those bridge jacks are damn cool!
Regards,
Leigh
Pontiacs I’ve owned….
1960 Laurentian 283
1963 Laurentian 283
1976 Trans Am 400
1977 Trans Am 400
1951 Chieftain Flat head 6
1967 Firebird 400 convertible
1967 Firebird 400 coupe
1979 Trans Am 403
1971 Formula 455 (clone)
1969 Firebird 350
1968 Firebird 428 manual.
Sydney, Australia
Old 10-04-2013, 07:54 AM
arbys's Avatar
Originally Posted by The Champ View Post
Doing brakes...
Thanks, that just sold me on the 4 post.
Old 10-04-2013, 08:54 AM
ho428's Avatar
I've used the jacks on the slider a lot, but I've also raised the car on the 4 post, put jack stands on the floor and lowered the car onto the jack stands to get all 4 wheels off quickly, basically used the lift as a jack.
Rolled around on the stool like doing a normal jack stand brake job.
Old 10-04-2013, 09:08 AM
Anything more than three cars is ridiculous. And Im so jealous.
