Old 11-29-2013, 12:01 AM
SD73's Avatar
SD73 SD73 is offline
Default 72-73 Throttle Cable Question
I'm looking to buy one of these for a 4bbl car. Can anyone that has one out take a few measurements? It would help me a heck of a lot trying to identify the correct one.
The main question is the total length of your cable end-to-end? I don't have that question in my pic.
Then attached in the pic are a few other questions I have. The length of the black tube I'm finding a little variance so I'd like to get a few more numbers. I'm thinking the factory had it at about 11.5 inch give or take 1/4 inch but more numbers would be helpful. My guess is with that tube variance they relied on the total fixed length of the cable.
Any help you guys have would be greatly appreciated even if you can't answer all the questions. One friend used a string to measure the black tube on the car for an accurate measurement.
Name:	Throttle cable.jpg
Old 12-03-2013, 12:44 AM
Formulabruce's Avatar
I ended up using a cable from Napa that I ordered per application, but the firewall end was not square, it was rectangle, and I shaved it to use it. You cant tell. If I can find that info Ill post it here. the parts place used to sell one, but as I recall it was not correct.
The Following User Says Thank You to Formulabruce For This Useful Post:
Old 12-03-2013, 01:11 AM
SD73's Avatar
Yeah. There is a repro and it's short. It's listed as correct for two more years than just 72/73. I think once I get a few more accurate measurement of the total length of the cable I should be able to make a correct looking one out of some cores I have that are very close in everything but the total length. But the more info I get on the details the better I'll get in my final outcome so more measurement are always welcome! Thanks for the bump, Bruce!
Old 12-03-2013, 06:10 AM
ORBIT 433's Avatar
ORBIT 433 ORBIT 433 is offline
The parts place seems to offer one.
Old 12-03-2013, 11:54 AM
SD73's Avatar
The Parts Place one is wrong. Theirs is marketed for something like 70-74 Birds where the cable is a 72/73 only part. There's is too short as well.
Old 12-03-2013, 07:18 PM
ORBIT 433's Avatar
Good to know
Old 12-03-2013, 07:52 PM
njsteve's Avatar
njsteve njsteve is offline
Gee, I can't remember how many times I've overheard ladies ask that question in a bar.
Old 12-03-2013, 08:38 PM
SD73's Avatar
Leave your cable envy out of my thread!
Old 12-03-2013, 10:12 PM
Have several used '72-73 4 bbl cables in a parts tub of nothing but cables. Have a good sized list to get completed before tomorrow PM. Should be able to dig the tub out later this week when stuck inside with ice & snow pounding us. Will take measurements.
Old 12-03-2013, 10:27 PM
SD73's Avatar
That would be fantastic!
Don't be afraid to PM me too if you find one you want to sell or trade if you're looking for something.
Old 12-11-2013, 10:13 PM
SD73's Avatar
BUMPing to see if any of you guys have had a chance to look through your stuff yet. I'm especially looking for the End-to-End length. That long black tube length would be helpful too, but I'm good on the rest of my questions.
Member transam1972 did me a huge favor and sent me his NOS unit to look at and it's been an incredible help and he's a terrific guy so big thanks Glenn! Since he doesn't have the part number I'd still like to confirm that total length with at least a couple more members.
The Following User Says Thank You to SD73 For This Useful Post:
Old 12-12-2013, 01:12 AM
Here is the Numbers...
Old 12-12-2013, 02:12 AM
SD73's Avatar
Thanks Bruce. It's that 616 I'm after. Figures it's like the 666 beast and tough to get a bead on.
Anyone with that total length? Anyone?
Old 12-12-2013, 08:16 AM
Judge273's Avatar
Judge273 Judge273 is offline
Can you measure while its on car? Firewall to bracket? Mine is +/= 11.5 inches in -2 degrees. FWIW and the ladies....
Mike/Illinois
Old 12-12-2013, 11:10 AM
transam1972 transam1972 is offline
Default cable length
so that's what they meant when they said, 'Here comes the Judge!"
The Following User Says Thank You to transam1972 For This Useful Post:
Old 12-12-2013, 12:04 PM
SD73's Avatar
The Judge is in the room. Yeah, measuring installed is fine too. Especially in -2 weather. If possible just a measurement of the black tube to the grommets will give me what I need and a piece of string works well to get it.
Old 12-12-2013, 11:45 PM
SD73's Avatar
Okay, well this is turning into the Tale of Two Throttle Cables.
So it boils down for me to getting a good total length of a known 72/73 4bbl Cable and I think I can make my own repro from there.
I have two sources of conflicting info on the total, end-to-end length of these cables. An eBay seller had an NOS part# 545616 that measured in at 24.25in.
I also have in my custody by the more than generous and illustrious member Transam1972 a cable he bought as NOS 20 years ago that measures 22.5 inches.
If someone can confirm the markings are correct for a 545616 or has any other way of IDing it that would be phenomenal. There is a tag with an "SP" that may translate to something. The other NOS one had a "PD" on it and a friend with a '73 has a "PB" on his. Of course if you have on out of car that I can get an end-to-end on that would be excellent!
ID:	346300   Click image for larger version
ID:	346301   Click image for larger version
Old 12-13-2013, 01:34 AM
I have an old one from my 73 & I will measure it as it's out right now & get back to you.
Old 12-13-2013, 01:50 AM
I went out in the garage to find the cable but it's only about -3 deg's out right now & it wasn't in the spot I thought it was so the next time I'm out & have the heat on I'll look for it a bit more in the warm & get back to you on the total length . I do know the one I had did have an off white end (carb end) on it. The cable is black along with the square pieces that hold it in place.
The Following User Says Thank You to rexs73gto For This Useful Post:
Old 12-13-2013, 12:08 PM
SD73's Avatar
Hey Rex, that would be a giant help! If possible could you also measure the part of the cable that extends past the bottom grommet that attaches to the gas pedal? I just thought of another method that may make making one of these easier.
Also, if you'd consider selling please PM me too.
