There is a shop nearby that will sandblast and powdercoat frames for $300. Not a bad deal at all, but how does a rusty frame that is blasted, then powdercoated turn out? Is pitting typically filled in with the powdercoating? Or is blasting/primer/filler/painting the only way to go to get a frame to look like new? Anyone with experience with this? thanks!!
Norm J |
The pitting will remain. If you want to powder paint you can fill the pits with JB Weld. It will survive the baking process.
Eastwood sells a filler made for powder coating.
http://www.eastwood.com/hi-temp-lab-metal-24-oz.html
GoatDr |
Tripower, please do a search on here for the pros and cons of both powder and priming/painting before you decide. Much info has been posted here in the past that will help you with your decision.
![]() Quote:
![]() Quote:
I've done a lot of research on here and other websites and have decided to use Rustoleum's professional Grade paint on my 65's chassis, I believe it''ll be fine. I've used standard Rustoleum on everything around here that sit'e outside year round and it still looks good a lot of years later.
![]() Quote:
69 455/4-sp windward blue under major restoration 69 400/400 waiting for resto Last edited by jetallman; 12-29-2013 at 09:00 PM. |
I actually picked up a gallon today at Menards, going to paint the frame soon. My car is custom, so I went with gloss black.
I used a foam roller and put on 3 coats of the Rustoleum professional and it turned out great.
Dave "Big Injun" Anderson dave@4mypontiac.com www.4mypontiac.com For GTO Celebration items click the tile coaster. ![]() |
+1 on the Rustoleum. I mix half and half gloss and flat, you can adjust the ratio to suit your desired "gloss". I usually put in some Velspar hardener, dries tough as nails, very, very durable. Will easily last longer than the OEM frame paint.
JohnnyB |
![]() Paid about $500 dollars to blast my frame. So you have a good deal going. Finished mine up with the entire POR-15 paint system. sitting out in the sun early in the fall to dry. The best close up shots I have. Good luck on your project. |
I want to keep mine as is, but if i painted it, I would go this route.
http://www.youtube.com/watch?v=Qf1Z72Vj-iM |
