Idle speed solenoid
Does anyone know who makes or where I can find the bolts that mounts the solenoid to the carb? This is for the SD cars and also 4spd cars. Two (2) required.
bolts
do you mean the bolt securing the solenoid to the bracket...or the bolts that secure the carb. to the manifold, that also secures the bracket the solenoid is attatched to?
If you have the part number try AMK.
I've got a pair of originals. Send me a PM
Not sure how the SD might differ from a 455HO if at all, but here is a 455HO setup. Inline tube has the correct brackets, bolts and nuts if that's what you need.
The Following 2 Users Say Thank You to Bentwheelbob For This Useful Post: | ||
Bob,
'73 and '74 use a completely different setup. There are 2 bolts that screw into the front of the carb body, rather than the front carb bolt like a '71 or '72 HO, but appreciate your input |
Yes, you are correct two (2) screws that hold the bracket to the front of the carb. The group # is 3.444 part # is 10004391 out of the Pontiac book. In 73-74 the way that the bracket attached changed. Pontiac calls it a bolt it is what we call a screw go figure.
The Following User Says Thank You to formula kid For This Useful Post: | ||
.I did not think that 72 and 73 would be so different...however Inline Tube has some great stuff that no one else carries!
Anyone have a pic or two of the '73? Idle solenoid? my pics have air cleaners. Thanks!
May have to run one on my AC car, but Ill surely use a 76-80 Carb.
"The Future Belongs to those who are STILL Willing to get their Hands Dirty" .. my Grandfather |
I've seen hex bolts and slotted screws.
http://www.pontiacpower.org/ |
The Following 2 Users Say Thank You to fiedlerh For This Useful Post: | ||
your second pic shows the correct ones. They have a flat head screwdriver type head on them with a bolt thread, so they are actually bolts.
your first pic is a Service Replacement carb, thus the hex head bolts (think that was Lloyd's old carb)... |
The second is the correct type. Thank you.
Here is a shot of the original( not working, in case someone has one to sell) attachment to the original carb.
Boy, it's hard to tell, but I think you're right in that fiedlerh second pic is correct.
Does anyone know the bolt size and the thread count?
It looks like both of those carbs are SD-455. One looks to be a replacement the other original.
T/A Kids parts
I was lost at the 2nd post...does anyone have the parts the Kid needs?...and pre Happy New Year!!
No, I'm using mine, sorry.
The Group #3.444 idle solenoid bracket attaching screw, 7030567, is (I believe) a #12-28 x 1/2" machine screw. But, don't quote me on the size yet. And, yes, the second carb is a '4273 unit. |
The Following 2 Users Say Thank You to Held for Ransom For This Useful Post: | ||
The bolt is from the REV. 4/83 Group 3.444 part # 10004391. Works for all 73 400 Mt, all 73 455. All 74 400 4BC MT exc. Alt perf. All 74 SD
wonder why its not listing automatic as an application too..
