1967 Le Mans Speedometer needle removal
I am going to replace the "face plate" of my speedometer gauge on my 67 Le Mans with one I picked up out of a junk yard and I was wondering how hard is it going to be to take off the needle from the speedo gauge? My gauge the numbers were faded out real bad, and there was rust on it also, I was able to break the screws loose after letting them soak with PB Blaster, that was the part I worried about. But I have not touched the needle, as I did not want to break it. I assume it is pushed on? and possibly there is a flat on the shaft to "clock" it back if the right position, or you just push it on, at the zero?
Any suggestions, or help from some one who has had one off would be welcome. Thanks guys Rusty in NC |
Hold the shaft with long nose pliers and twist & pull gently with your fingers on the hub of the needle. Same procedure for replacement, but may require repositioning a time or two to get it right. Be VERY careful with that shaft!
A while back i was going to set my odometer back to 0 but i needed to remove the pointer to do it. That bugger was on ther pretty well. I diidn`t want to mess it up so i gave up.
George
Thank you for the reply Old Goat 67. I will give that a try the next time I get to my shop to work on the car. I appreciate the reply!
Remove it counter clockwise, on clockwise.
Practicing social distancing for 65+ years |
You could also contact Pete Serio and have it rebuilt ,relubed and recalibrated and not have to worry about breaking the needle...ask me how I know..
X2 they spin off and on..
Speedometer Pointer Removal
Be VERY, very careful. If this is the first time you are trying to do this there is roughly a 50-50 chance your going to break something. If you twist off the pointer and the shaft end (which is about 3/32" of metal) breaks off in the back of the pointer, flush; the parts to fix what you just broke can ONLY come from another good used speedometer.
A pointer for a 1960s GM car speedometer is no longer available as a service part (has not been for over 30 years). Many old speedometers are damaged beyond repair by people messing around with them if you don't have the proper tools or training.
The Following User Says Thank You to Peter Serio For This Useful Post: | ||
If you break it I have a speedo cheap..never had an issue taking them off just don't overtighten it
Thanks for all the replies and advice. I have not yet attempted to try to make the switch yet, it has just been way too cold out in the shop to do any work, and I have been busy around the house doing other things. As always, I appreciate the amount of knowledge that is freely shared here in the forum. Thank you all!
Rusty in NC |
Thread Tools | |
Display Modes | |
