Old 01-22-2014, 03:39 PM
quick67bird's Avatar
quick67bird quick67bird is offline
Default Maximum compression with a turbo
I have aluminum D port heads that I am wondering what the maximum compression can be ran on E-85. It is a street engine that will be raced once a while. Mainly a grudge/ who is faster type of car for my group of friends.
The heads are 72 cc 340 cfm version from KRE that have been reworked by SD Performance.
67 Firebird 467 cubic inches 7.71 @ 92 in the 1/8 and 11.69 @ 115 in the 1/4.
Old 01-22-2014, 03:59 PM
bignate's Avatar
bignate bignate is offline
I don't have any real world experience with it, but I have been researching a supercharged E-85 application I'd like to build someday.
Everything I have seen online about E-85 is that no one really knows its limit yet. I have seen a few references to guys running 10.5:1 and 15-20 or more lbs. of boost, without problems. Albeit these are LSX and Mustang applications that I've read about.
Another FYI, if nitrous is ever going to be thought about, it works with E-85 but it's not as potent as it is with gas. The E-85 already significantly cools the intake charge, so you lose that benefit of N2O.
Nate
1970 "Real" Judge RAIII 4-speed, Atoll Blue w/painted white top. Mild RAIV headed 400 motor in now.
The Following User Says Thank You to bignate For This Useful Post:
Old 01-22-2014, 04:43 PM
Nate
I thought about nitrous and have a bigshot plate, but I am looking toward turbos for more consistent power.
Old 01-22-2014, 05:08 PM
David Holmberg's Avatar
I'll say the same thing I said on the Bullet, you need to be talking to Travis Quillen.
There are lots of pluses and minuses, depending on your goal and intended use.
The Following User Says Thank You to David Holmberg For This Useful Post:
Old 01-22-2014, 05:42 PM
I definitely be talking to Travis. I don't want to waste his time till I have the resources to move forward.
Old 01-22-2014, 05:56 PM
The thought process has changed so much, very quickly.
If I even knew the right answer it would probably be wrong by the time you talk with Travis.
Old 01-22-2014, 08:43 PM
I have been seeing that the technology is changing quickly. I just don't want to bother him needlessly till I am ready.
Old 01-22-2014, 08:48 PM
grandville455's Avatar
grandville455 grandville455 is offline
I didn't know u could get 340 out of the KRE D ports?
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,7.33@94.55-11.502@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32
M/T 275/60 ET SS Drag Radial
2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's
Old 01-22-2014, 09:47 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Yes from KRE.
The Following User Says Thank You to ponjohn For This Useful Post:
Old 01-22-2014, 10:12 PM
Big Nate about summed it up... how much compression is determined by a bunch of factors... manifold air temp(compressor discharge temp) chamber layout, A/F ratio, cylinder to cylinder variations, possibly dynamic compression to some extent, probably more.
Lots of subject material over on Yellow Bullet in the turbo section.
The Following User Says Thank You to BruceWilkie For This Useful Post:
Old 01-22-2014, 11:31 PM
cgeise's Avatar
cgeise cgeise is offline
The higher the cr the smaller the tune window, I have heard of 11to1 with alcohol. with a turbo if you need more power -- add boost -- lol but id say e-85 and 10 to 1 with moderate boost should be fine
The Following User Says Thank You to cgeise For This Useful Post:
Old 01-22-2014, 11:48 PM
rodneybutler's Avatar
rodneybutler rodneybutler is offline
I agree with Curt. I did an LS RHS aluminum engine with single turbo for a H2 Hummer. 9:1 compression on E85. Made 1600 hp with a bunch of boost. Problem was the engine was lazy until the boost came on and then was uncontrollable. Now the customer wants less hp and more drivability. So I'm upping the compression for less boost. Funny how people think they want big power until they get it! Lol
The Following User Says Thank You to rodneybutler For This Useful Post:
Old 01-22-2014, 11:51 PM
cgeise's Avatar
LOL ---- BEEN THERE DONE THAT
Old 01-23-2014, 02:19 AM
demonic68's Avatar
demonic68 demonic68 is offline
You can always add more boost in the end start low and work your way up if more is needed. The nice thing about turbos are boost controllers
The Following User Says Thank You to demonic68 For This Useful Post:
Old 01-23-2014, 03:23 AM
They were the 340 cfm heads from KRE that I sent up to Dave and he reworked them a bit and picked up a little cfm in the low lift areas. I have my flow sheet posted in one of my posts.
Old 01-23-2014, 03:35 AM
I was thinking of using parts I already have so that is why I am at 11 to 1. I appreciate you responding Curt as you have one of my favorite cars and compete at a high level successfully.
The Following User Says Thank You to quick67bird For This Useful Post:
Old 01-23-2014, 03:37 AM
Thanks Rodney. I will be contacting you and Travis soon.
Old 01-23-2014, 04:00 AM
I have a stout short block already and the KRE heads. I would like to get some DCI RA V in the future.
Old 01-23-2014, 01:05 PM
cgeise's Avatar
Not many of us up here in the NW -- let me know if you need any help - we have some good resourses here locally also --
Old 01-28-2014, 04:41 PM
Thanks Curt. I appreciate the offer and when I move forward I would love to have some input from you.
