Bad69Bird
At only 477 ci that really is awesome! Did you ever dyno your engine? For my simulation I am using around 1270 HP and torque 980. For my simulation to some what match your run I had to pull power out until about 87 feet out and then had it shifting into second at about 101 feet out. Stan PS - I would guess that you are doing this running less than one bar of boost.
When I simulate Kinsler's 8.42 N/A run he has over 2 G's down low
60 Foot ET = 1.1675 330 Foot ET = 3.3967 1/8 Mile ET = 5.3293 1/8 Mile MPH = 126.6948 1000 Foot ET = 7.0071 1/4 Mile ET = 8.4242 1/4 Mile MPH = 159.7267 When I simulate your run you have just a little over 1.5 G's If you get your car to hook like Kinsler's 60 Foot ET = 1.1642 330 Foot ET = 3.2924 1/8 Mile ET = 5.1296 1/8 Mile MPH = 133.3245 1000 Foot ET = 6.7235 1/4 Mile ET = 8.0694 1/4 Mile MPH = 168.1848 Note this is still at 3900 foot DA. Stan
Where you pulled the power out is close too. I was using a RPM based retard curve and that is prolly right around where the power started coming back in. Quote:
East Coast Mafia TTFMF Making CVWHAT's great again. I guess it took a deplorable ECM member to do it! Quote:
Fastest Blow-thru Pontiac powered car in the Country 8.440@166.97 (3465lbs) Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: 4.80@147.65/ 7.49@180.12MPH (3365lbs) |
Between what you've learned and the new Pro tires your 60 will rock!
First CV1 in the 7's right here folks, write it down! |
The Following 4 Users Say Thank You to David Holmberg For This Useful Post: | ||
He would probably get a lifetime membership to the CV1Channel for that!!!
First Pontiac powered street car in the 7's 7.940@170.84. 3460#s |
The Following 5 Users Say Thank You to LiL Jack For This Useful Post: | ||
or at least a batman video
EHTTFMF! Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead. BEING STUPID WORKS THE SAME WAY! The rest of us suffer. |
The Following 5 Users Say Thank You to mike leech For This Useful Post: | ||
Im betting he wont be the first. Mark it down, here is a pic you can add to your computers wall paper just to keep it fresh in your mind. |
The Following 4 Users Say Thank You to jdw_poncho For This Useful Post: | ||
Very cool car. Get it moving man and let's see a great number. I'm looking foward to it.
Get it going and drop Big Chief a note. He claimed to be leaning the CV-1 way, you might be able to share some info. Good luck and that's a cool car. Well done. |
I made a post but it disappeared... Damn Moderators. You might be right, its not at the top of Brian's list of priorities right now, but it will happen. That's a cool car! |
BTW your post went in the 2014 prediction thread. |
The Following User Says Thank You to jdw_poncho For This Useful Post: | ||
As long as I dont make some stupid tuning mistake I think the car will do well. I'd like to see someone else boost a set of cv-1's but I'll bet Big chief ends up with billets if he has issues with the e-heads. We'll see... |
Stan, back to the original post. I'm betting Brian is not blowing more than .6 bar on his engine.
1 Bar = 14.5 psi .6 x 14.5 = 8.7 psi of boost. (Add 20 psi to that number and you would be close with the CV-1 heads). Tom V.
Only if the cam and exh system is a pos and I'm betting it's not.
I'm quite capable of running the conversion of units but thanks for doing the donkey work for us. Thanks for your input omniscient one. |
The Following 3 Users Say Thank You to Aaron Quinton For This Useful Post: | ||
Maybe everyone else cannot do the conversion so easily Aaron, some think a Bar is 14.7 psi. Just passing on info. Why would you need a F-2 supercharger if you were only running 8 psi of boost. The board is not all about you, Aaron.
Low 8s on 8 psi, Right. Tom Vaught
A lot of possibilities this year!
DOC'S TA Turbo 535, CV 1 heads. Built by Cerralli Competition Engines Tenth Anniversary (Van Nuys) restored. Tenth Anniversary Barn Find (Norwood) Both 4 speeds! |
Thanks for the 1.4% correction on pressure conversion for those who aren't keeping up on the board.
That would be 9 psi using proper rounding techniques with your engineering math bro. lol Quote:
damn i need to lighten up my car. maybe i can run it by remote control. lol
-Rob 67 LE MANS in pieces... 68 gto 84 grand prix twin turbo 496 pontiac 25.3 cage |
PSI absolute vs psi gauge.... last time I looked at psi it was on a gauge, engineers always thinking... LOL leave it to a technician to build it and use it.
The Following 2 Users Say Thank You to v869tr6 For This Useful Post: | ||
Let me know what you come up with.....
