Project 69 Firebird
Only thing holding back to get my project done is a Starter and Distributor anyone have one, know where to get one or have any recommendations. The Distributor that came with the engine is all seized up and came with no starter parts stores around don't have them. the Engine is out of 1968 Firebird OHC.
I've seen both on Rock Auto.
The Following User Says Thank You to 66sprint6 For This Useful Post: | ||
I may be able to help again, if Rock Auto parts end up being Chevy 6 parts.
The Following User Says Thank You to sprintbird For This Useful Post: | ||
Advance auto. $42 for a points distributor. $50 for a starter. Buy online and use promo code trt30 and get $30% off. have it delivered to your local store for free shipping...
The Following User Says Thank You to DOC For This Useful Post: | ||
I've been reading about a Pertronix conversion for the distributor or is there a HEI one?
More then likely, Autozone and O'relly's is selling chev motor mounts as Pontiac OHC mounts. What help you have?
Where you located?
I have stater cone for OHC and Dist. Cheers
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. |
The Following User Says Thank You to Jeff Hamlin For This Useful Post: | ||
No bolt in HEI units are available, though I do run an HEI on my car, it was a conversion done for me by Tom Langdon of Stovebolt Motors.
Jeff R 60 Jaguar Mark 2, 3.8L Automatic 67 Sprint Firebird 230 OHC-6 4-Speed A/C 78 Catlina Safari, Pontiac 400 powered 77 Astre Formula, 215 Buick V-8 T-5 73 Lemans Safari, 400 4bbl 4-speed 71 Catalina Enforcer, 455 4bbl 06 Mallet Solstice #024 LS2, Now with a Tremec 6060 6-speed! 2012 F-150 Echo Boost (My local Ford Dealer SUX!!!) 2020 Dodge Charger Scat pack (recovered) |
The Following User Says Thank You to camerjeff For This Useful Post: | ||
[QUOTE=Jeff Hamlin;5131610]Where you located?
I have stater cone for OHC and Dist. Cheers[/Q I live in Tacoma,WA. How much you want for the 2? |
Scratch that one about Rock Auto for the starter. I decided to buy one just to have and it said that there were none available. It does show the distributor as being avaiable, but I don't need one. I went on Napa's website and they show two models. One with nine teeth and one with ten. Anybody know how many teeth our starter has?
Grokk,
Let me pull them out and confirm condition and I'll let you know ASAP. Currently I know of NO starters avail in the aftermarket. 66sprint, I just ran a search on Napa's site and only came up with 1 I'm unaware of any options other than HD which I don't think is offered.
FYI.
OK I'm getting conflicting info; Autozone & Advance Auto again are showing Starters. However I only went to the check out online but did not attempt to complete purchase so don't if you will get a prompt stating it's unavailable? Might be worth calling if interested. Grokk, I do have a good functional distb as well as the starter cone or the whole starter if needed, but it needs rebuild. If interested in both how's $50.00+ship. Should be able to go large flate rate for $18. LMK if I can help further.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. Last edited by Jeff Hamlin; 03-08-2015 at 08:22 AM. |
Sweet, I'll Take them. How you want to do this Transaction?
69 OHC ZH Sprint Hurst 3 Speed 3:55 (1 of 213) 99 Valkyrie 1520cc Flat 6 108hp/110tq - For Sale http://sohcsix.yuku.com/forums/1/OHC-lounge Wanted: 1969 OHC "H" Camshaft |
Grokk,
PM sent with payment info. Thanks That is correct you can swap the cone onto a good starter.
I went to checkout in the Advance site and it came up as unavailable.
Autozone same thing.
Yep,
Just went all the way to check out, then SORRY ALL OUT
What starter can we switch our nose cone over to? One for a 326, or a 400? Any one with 9 teeth and a clockwise rotation?
The cone is the only thing needed to use a V8 starter 66-69.
Rotation and tooth count ? I have never heard of a tooth count difference in OHC starters? Standard Vs. HD are the only references I've dealt with for starters. I was just looking at Nappa's site and found 2 listed starters and did not see anything about tooth count. Part Number: RAY 2464800 Product Line: NAPA Power Premium Plus This one has a green check indicating in stock.
