Old 03-17-2014, 03:51 PM
70gteeo's Avatar
70gteeo 70gteeo is offline
Default 67 firebird Need Torque Spec's for front subframe body mounts
Need torque spec's for the core support and the body mounts. Thanks
The first betrayal is what they did to you.
The second betrayal is what you do to yourself.
1967 Firebird 400 convertible 4 speed #'s matching
2002 SOM Trans Am WS6 Convertible 6 speed bone stock
1970 GTO convertible auto #'s matching
Old 03-17-2014, 06:07 PM
sts sts is offline
They should be in the '67 Pontiac Service Manual, and here is a free copy of the book.
Click "libary," then select the '67 Manual.
http://thefirstgensite.com/
Old 03-17-2014, 06:58 PM
70gteeo's Avatar
I have the service manual and was not able to locate the torque spec's.
Old 03-17-2014, 07:21 PM
Dr.Corvette Dr.Corvette is offline
Core support bolts are 30-40 ft./lbs
Frame bolts are 75-95 ft./lbs
Torque specs are from the 67 Camaro assembly manual.
Hope this helps
Old 03-18-2014, 07:51 AM
70gteeo's Avatar
Dr.Corvette thanks for the torque spec's.
