Which converter
My combo is below: Well tomorrow I get my 8th transmission since last fall. This one is a new case and starting over and not using my existing trans. I have a TCI that I just had sent to be rebuilt and its a 4k that slips about 7 percent which im told is good. While the tranny is out I was given a 4500 Hughes to use to see if I can get better track#. My tranny guy is telling me a 3500 would be best????? Thoughts??? Thanks in advance
461 Stroker: 265/276 Comp Cam Solid roller . 340CFM E-Head Victor Intake 1050 Dom Carb. 390/430 9" Gears with a T400 trans 4200 converter. Street weight 3850. 1.49 60ft. 275/60/15 M/T DR 10.57 SO FAR |
We have similar combos except your cam is a little bigger than mine (262/266@0.050" SR). My converter flashes to around 4500-4700 ish rpm and slips 6.8% on the big end. I would think that you would need something that flashes to 4500 rpm not 3500 rpm with your cam. That doesn't mean the Hughes will flash to 4500 unless it was already behind a motor making similar power as yours.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
4500+ would work much better than a 3500, unless you street drive it 90% of the time.
8 transmissions????? Somebody or something is not right.
Mounting issues putting undue stress on the case/parts?? Driveshaft not balanced?? Converter/Flexplate/crank hub misalignments?? Converter in too far, not enough?? Driveshaft in too far/ not enough?? Rearend broken??
1978 Pontiac Grand LeMans.......out next year Previous - 2001 Jerry Haas-built P/S Grand Am - former WJ car, Hoffman Racing 535" IA2, Tiger Heads/Intake, Single Dominator, PG Best ET: 7.776 @ 175.94, 1.096 60', 2375 lbs. |
Its in the trans. He gives it back no reverse. Next it wont have 2nd or third. Its in his rebuid???? I have broken 2 HD sprags
I think that's his thinking
...X2
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0 2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion and 2015 IHRA Div 5 Mod champion |
I have a 5200 ATI 8" that works awesome.
I have a 315 ehead 455 with a 269/269 at 050 cam. |
I think you should be more concerned with getting a trans rebuilt correctly than worrying about the converter.
Same tranny guy again??
He started from scratch with a different case. Its DONE again Will test drive it tomorrow. I put the 4500 in it to see the difference.
In the TA with the old roller cam motor when I swapped in a fresh TH 350 for my slipping one we found my 4500 stall was toast(bearing peices floating around) so the only one I had was an A-1 I had restalled for the 400 as it was too tight initially in it. It stalled 5000, flashed to almost 300 just pulling on the trailer loose as heck probably 8-10% top end slippage but it and a good tranny picked the car up 0.75 seconds and picked up the 60 foot by 0.25!
Do you have a dyno sheet either engine or chassis?
If not take a rough guess and try and bring the converter in around peak TQ or a hair above that. This should help the 60 ft and my experience with stall speeds for street use has been about the same meaning whether it was a 3000 stall or 4500 stall the street ability was the same. If the converter won't couple and you drive through it then that's not good either on the big end. If the rest of your combo is solid and the chassis is working the converter will make or break you. I don't race my Pontiac at the track but I do my Grand National and in those cars the converter is critical. I picked up 7 tenths and 9 mph with a converter swap. That's a turbo car though but you get the idea.
Black 1978 Trans Am SE Clone Butler Performance 474 E heads Built 400 Trans with 3000 stall 17" Y/O 1978 Y88 4 Speed T Top PHS Docs Restored 1987 Grand national 4.1 Stroker Motor Just a 6 Cylinder Buick |
WOW!!!!! What a difference. I like this 4500 stall. Thanks Calvin!!!! Going to Cordova the 22nd
Did u have a manual valve body put in the trans?
No I didn't
You should be real happy with that converter. I had it built for my combo which is very similar to yours. I picked up 2.5 tenths from my B&M 4000. It should stall a little higher than 4500 probably 4700ish Rpm
Tom Syron |
I would find a new trans guy. 8 trans, what the... 2 broken HD sprags. I do my own 400s and have not had a issue. Just bought the Sessions book and did it myself.
Not trying to bash, but I would not be happy at all to have 340 E heads and run that ET. I have a car that weighs at least that much (69GTO) with a vary basic pump gas 455 with iron HOs,9.3 CR and a 850 and gone 10.96. I would have to believe that I could get down to the mid 10 range with those heads. Something's not quite right. Maybe your new converter will get you where you want to be. I had PTC build me one and I gained 3 tenths. Can not say enough good things about PTC. They will have a my converter business from here on out. |
4500 stall and no manual valve body , makes for rolled sprags , at this level it just makes sense to run a manual so u can start your burnout in second IMO
I might go to Cordova as well, might see you there. The added stall is a good thing imo.
