Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here. |
Lot of parts for sale all new but the roller rockers
Melling 10540 race oil pump with butler cooper intake gasket $75 Melling IS-54a oil pump drive rod. $5 ea Wix oil filters 51258 $5ea have 12 New GTO (or all pontiacs) t stat housing with gasket $10 Mr Gasket 4363 160deg t stat $10 ea Mr Gasket 4364 180deg t stat $10 ea Timing cover seal National 332062 $5 ea Remote oil adaptor to run a remote oil filter $30 Champion 58 plugs 50 cents ea have 16 Autolite 3924 plugs $1 ea have16 NGK r5672a-8 $15 for 8 Pioneer steel block and heads freeze plugs $15 SCE 4128 d port cooper exhaust gasket $25 NOT in picture Tin Indian RM300 Viton main seal $25 Crane Cam engerizer roller rocker (used for less then 50 miles) 28747-16 / 1.65 ratio but NO POLY LOCKS $125 You pay all shipping but if you need some of this stuff can save on shipping in one box |
I'll take the 3924 plugs.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
AG just to be clear they are only 3924 not the AR 3924 race plugs
Private mail!
Bump
PM sent.
Parts sold
Oil adaptor Autolite plugs Mr gasket 160 t stat. Thank you all and PY T stat housing Rm 300 seal Bump Bump Bump. On the parts left |
Bump. All t stats gone also like to thanks all that have purchased
Wix filers Sold
Melling shaft Sold Only have 1 pioneer block plug left no head plugs. If you need block only $10 + shipping |
are the roller rockers for 3/8 or 7/16 studs ?
7/16 I have the part number with the add so if needed check specs on summit racing
Do you think they will fit under stock height valve covers on KRE D port heads?
I would say no but it may under your covers also you can try a 5/16 gasket but again I will not say yes, Can anybody help ??? Anyway I love the valvecovers
Thanx they are pretty!
Ill take the rocker arms if still available. PM sent.
Fast PM returned
Rocker are sold
Oil pump sold
