Hi, need some help identifying these rods and bolts. I think they are Tomahawks w/8740 bolts but not positive. They are a .980 floating small end, 7/16 bolt head & threads, aprox 8 years old
Thanks, John Last edited by BB70; 07-08-2014 at 12:26 PM. |
The rod cap marks and overall design appear very similar to a set I got from Ace PPR about the same time frame. I don't remember the.beams.being marked but it was a while ago. I never had an issue with them. They took a beating
1969 carousel red firebird 455, richmond 5 speed 1964 540 gto 1971 lemans sport convertible 1972 Maverick under slow construction |
![]() Quote:
From what I'm finding for 8740 bolts its 66ftlb, .005-.0055. John |
Just use the arp spec
The ink stamping for the C to C length leads me to say that they are Eagle.
Not an eagle rod. Does not have the machined rib down the center of the "H"
Less said,,,,,,,, Less mended. |
![]() Quote:
Pretty sure Aces rods came from RPM... Good rods! |
They look like the Tomahawks I have in my 406. I bought them in 04, still in the engine with original bearings, been checked a few times, still looked real good the last time I had it down couple years ago. My son-in-law owns it now, just sitting. I just looked up the torque specks he sent me with the rods, 65 ft lbs no less, no more. The engine has many passes turning 6500 or better, was still running good when we pulled it.
Thanks for all the input, you guys and this website are great.
![]() John |
The lube used is very important. 65 LBS. with ARP Ultralube would be about right. If 30 weight motor oil is used, you usually need to go about 15 lbs. more to get the same stretch. I prefer to use ARP Ultralube. It's more consistent. The correct stretch will probably be more like .006"-.0065" for the 7/16" bolt.
I have spec sheets at work I will try to remember to double check in the morning. As mentioned already, it's NOT an Eagle rod.
![]() Quote:
I'm not sure when Ken started using RPM International, Inc. for his cranks and rods (RPM website), but he did for quite awhile up to the time he closed. They were located within 10 miles of his shop, but I see that they have moved to Brea, CA. It is very important to check products from all manufacturers today for defects, and that applies to their products.
