Vinyl upolstry paint - black
I've found my seats are showing red on wear areas, what is v good paint/dye I can apply for now to my driver. Seats t in great shape.
Any links to a "how-to" sites is much appreciated. TYVM, Robin |
I am going to use SEM brand on my door panels, Paint and Prep. I am going to try their prep as well, here is a link.
http://cgi.ebay.com/ws/eBayISAPI.dll...m=231270989171 If you do not use the prep, I would give the vinyl a good wipe down with 70/30 rubbing alcohol. |
Tyvm
You need a low-lustre clear coat also, acts as protection and seals it all.
If you use the SEM prep products (there are about 4 or so different steps/products) and after using the black (I use the Landau Black) top it off with the SEM clear you will get amazing results. It's not cheap and takes discipline and time to do it correctly, but is a lot less than buying new seat covers. I have tried Dupli Color and other products due to price and then stripped everything off, bought SEM products and had great results. You will need to buy SEM soap to scrub them down after you clean them with whatever you normally use i.e. grease and wax remover, simple green, etc. You will also need the adhesion promoter, use ALL SEM don't mix products with cheaper or maybe better i.e. bulldog adhesion promoter (some folks think it is better, it might be but use the SEM). Also use a tac rag between coats. Go up the SEM web page and it will spell out what you need to purchase and what to do. I think there is even YouTube videos.
1966 GTO Vert automatic. 1969 CR Judge Ram Air III 4sp Pattern Car. 1969 GTO standard 350HP TH-400. 2006 GTO Phantom Black 6spd. 1972 Formula 455HO Ram Air. 1976 LE Trans Am 50th Anniversary Edition with T top. 1976 Formula 350. 1977 Grand Prix Model J 350. 1978 Trans am 400 Pontiac. 1979 Trans am 403 Olds. 1968 Olds 442. 1971 TR6. |
