I have a worn out 326 I'm about to pull out of a 65 lemans. I also have a bare 73 455 block and crank I will be building with 6x heads in the near future. Will The timing cover, valley covers and oil pan from the 326 swap over without issues? Any other parts I can salvage from the 326 for the new build?
Yep, you can swap all of your external stuff to the 455 other than the 326 valve covers wont work on later 6X heads. Valley pan , timing cover, dipstick tube, and oil pan and balancer can be used from 326 and all the 326 pulleys and accesories keeping your 55 looking 65
63 Catalina coupe 467 cid budget drag car 11's 1/4 , 7.20 1/8th pump gas n/a 66 Star Chief Executive 57k mile 69 Le Mans 2 dr HT 350 85k mile 15 sec 1/4 69 Firebird 400 Burgandy/Black 70 Olds Rallye 350 F85 4 speed 3.91's 70 Olds Cutlass Cruiser Red Wagon 350 101k miles 15 sec 1/4 12 sec w 455 74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8 2020 RAM 1500 SLT 4x4 5.7 A8 Hemi 2007 Hummer H3 3.7 liter turd 2019 Chevy Spark petrol car 38 mpg |
The 455 will have both bolt patterns for the engine mounts so you can use the original 326 mounts on your 455 engine.
Tom V.
![]() Quote:
![]() Quote:
Pre-1967 engines used a 20-degree valve inclination, low-performance 1967 heads too which includes all 326 engines, this was a transition year. 1968 and later all were 14-degree heads (including all 1967 high-performance heads), which used a deeper valve cover design. |
