Old 10-07-2014, 10:18 AM
max 93 max 93 is offline
Default Brake upgrade
Has anyone installed LS1 one front brakes and been able to use 15" ralley wheels? From what I read, some 15 inch wheels will fit with a little grinding on the caliper fins. I was just wondering if anybody has actually done this. I am considering this for my 68 Firebird, but don't want to have to buy new wheels.
Old 10-09-2014, 10:26 AM
I can't be the only one to ever consider this swap
Old 10-09-2014, 01:15 PM
Schurkey Schurkey is offline
What the hell are LS1 brakes?
Old 10-09-2014, 01:46 PM
The brakes from a LS1 equipped 4th gen f body. It's a fairly easy swap.
Old 02-02-2019, 09:54 PM
leecorrell leecorrell is offline
Did you end up doing the LS1 brake swap? I'm considering the same thing for my 67 Lemans, but only if I can still use the 15" rally II wheels.
Old 02-02-2019, 10:39 PM
I bought the brackets, but never got around to mocking it up to see if my wheels would still fit
Old 02-03-2019, 11:15 AM
JSPONT's Avatar
JSPONT JSPONT is offline
I have ls 1 brakes on my 70 Lemans. I have 15 inch welds though. I had to run a spacer to clear the weld wheel. If I remember correct, the rim clears, it was where the rim curves in( the rallye might not do that)
