Old 11-08-2014, 09:19 AM
70 Blackbird 70 Blackbird is offline
Default 70 Formula AC Decal code
Can anyone tell me what the 2 character "picking" code and part number should be on the non ram air/non California air cleaner for a 70 Formula?
If someone could post a picture as well, that would be great!
Thanks!
Old 11-09-2014, 10:09 AM
Just to clairify, this decal is the "Keep your GM car all GM"...
Old 11-14-2014, 12:16 AM
Anyone?
Old 05-13-2023, 12:15 PM
blue71ta's Avatar
blue71ta blue71ta is offline
bringing this back up. I am looking for this info as well.
Anyone have a pic of an original 1970 Formula, dual snorkel air cleaner decal? (without Ram Air)
...or know what the correct 2 letter code should be? I see several different decals for sale with different codes on them
Old 05-13-2023, 04:09 PM
I never knew this thread was about air cleaners?
Thought it was for Air Conditioning.
Anyway don't really know the answer, but from some Van Nuys buildsheets, possibly 'RO' is for a non-RA air cleaner?
Don't have any Norwood buildsheets, and just a few for Formulas. Most for TA's. (still not many)
The Assembly Manual has a page for the Air cleaner part #'s:
Old 05-13-2023, 05:38 PM
Held for Ransom's Avatar
RO will be for ones with the carb. vent hole. It's out there. Just got to find one you'll like...
https://forums.maxperformanceinc.com...d.php?t=828192
So long, farewell.
Old 05-13-2023, 07:06 PM
Singleton Singleton is offline
My 70 Formula (non-Ram Air, invoice date of 5/11/70), has an air cleaner with code RO, (part # 6486116), ink stamp inside base 5/7/70. Norwood car, non-CA emissions. Air cleaner base has the vent hole with plug.
ID:	612609   Click image for larger version
66 GTO, 495, M22, Strange S-60 w/4.10
Sold new at Ace Wilson's Royal Pontiac
http://www.youtube.com/watch?v=cUHC-Z8xhtg
The Following User Says Thank You to Singleton For This Useful Post:
Old 05-13-2023, 07:42 PM
That one is out there too, but I don't like it.
So long, farewell.
Old 05-14-2023, 01:23 PM
blue71ta's Avatar
Excellent info - thanks everyone!
So HFR, who makes the best "RM" version in your opinion? The 3rd repro from your other thread:
Old 05-14-2023, 04:00 PM
According those numbers, my Norwood formula should have a 6485988, but has a RO 6486116 on it, (see my pics in previous post above).
Guess it’s possible that my air cleaner has been switched, but the date (5-7-70) is very close to the invoice date of car (5-11-70).
Old 05-14-2023, 05:51 PM
What is the difference between the 6485988 and what you have?
(don't know what the differences are other than the RA cleaner would be different?)
Is the 6485988 a RA air cleaner?
Pretty sure the 6486116 is not a RA air cleaner.
Never looked into the Air Cleaners, myself.
Old 05-14-2023, 06:11 PM
I believe that the 6485988 (RM) is the same as the 6486116 (RO), except the RO has the hole for the carburetor vent, (California carb). Both are non Ram Air dual snorkel. My understanding is the vent hole had a plastic plug in place on the RO when used on a non-CA car in 1970.
Seems the assembly manual is saying the Norwood used RA while Van nuys used RO, and with a plug if car was shipped outside Cali. I’m unsure.
The Following 2 Users Say Thank You to Singleton For This Useful Post:
Old 05-14-2023, 07:59 PM
That last line above should read “Norwood used RM while van nuys used RO”
Old 05-14-2023, 08:49 PM
Not sure of that?
The buildsheets I have for the Formulas without RA hoods have RO air cleaners. Don't know what the numbers for it are though. It justs shows 'RO'.
(why I said it probably was a RO code before)
Ones with RA hoods (air cleaners) had 'RR' as the pick code?
(TA had 'RS')
Old 05-14-2023, 08:52 PM
They also had NA9 (evap Emissions) and no HD air cleaner.
Old 05-15-2023, 09:20 PM
No BEST. The 3rd repro. was as close as I could get. If you're going to GTOAA Nationals or Ames shows, I can bring one to sell there.
The plug was rubber. The RO air cleaner, I believe, was the one stocked at Van Nuys and may have been available to Norwood after a while.
The Ram Air air cleaner decal (RR) is available and is like the RO in quality. The 6486117 (RP) HD air cleaner w/vent hole is not available in repro., nor is the 6485989 (don't know the pick code).
So long, farewell.
Old 05-16-2023, 12:20 PM
unruhjonny's Avatar
Ok, just to make sure I have this straight (because I previously thought I did);
1970 Formula aircleaner decals:
RR = L74 (RAIII) Van Nuys & Norwood.
RO = L78 (400/4bbl) Van Nuys; air cleaner assembly with vent hole - possibly used on some Norwood cars - but the carb vent hole plugged.
RM = L78 (400/4bbl) Norwood; air cleaner assembly without vent hole.
I previously only recall reading about RR & RM decals, and had thought the decal was about the air cleaner configuration, and had no bearing on plant, or presence/absence of the 70-CA vent hole ect.
I do not recall reading about this RO decal!
1970 Formula 400
Old 05-16-2023, 04:13 PM
Ram Air air cleaner had the one design, with the vent hole and plugged when correct carb. was used. I don't know why they didn't have one stamping (which the L78's air cleaners all basically were) and did the same with different air filters and plugs for the correct carbs. vs the two.
So long, farewell.
Old 05-21-2023, 04:50 PM
cpu's Avatar
cpu cpu is offline
One more data point: RM was the broadcast code used for my 04C Norwood Formula's L-78 (non-RA) air cleaner.
Carl
1970 Formula 400
The Following 2 Users Say Thank You to cpu For This Useful Post:
