Brake pedal spring to clevis bracket
Does anyone know where I can get this bracket? I have a 66 and it seems that no one carries it. Also does anyone have a picture of where the spring mounts on the opposite end. I am doing a disk conversion and it did not include the bracket and it seems like a long stretch for my spring in its current location. I guess i didnt pay enough attention when I removed it. Thanks Neil
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. |
Thanks Jeff, the artical had a lot about the clutch pedal but didnt clearly address my brake pedal question. N
I was focused on your question of how/where spring gets attached.
Article has prefect image of that. I checker my stash and NG on the spring retainer. You may be able to make one out of flat sheet stock?
I guess i missed that the first time. Thanks again.
Don't just look at that article. There's a whole bunch of great stuff in that link.
Good one Jeff. That goes for the clutch pedal article too.
If I recall correctly only cars without power brakes had the little piece that the brake pin went through to attach the return spring.
That is correct.
Also car in article is none PB.
Spring retainer;
thanks
