Performer and Holley Carb
IIRC the intake is drilled for both spread and square bore carbs, correct? Any general problems associated with bolting on a 750DP, other than the linkage and different fuel entry?
Robert 69 Firebird-462/Edel round ports/currently running the Holley Sniper/4sp/3.23posi/Deluxe Int/pwr st/vintage air/4wl disc( a work in progress-always ) http://youtu.be/eaWBd3M9MN4 |
They sell an extra plate but I never had problems with my 750 VS sealing.
I think they still sell the square flange plate to help seal the gasket to the spread bore intake. I always used the plate for piece of mind. I figure it helps support the holley base plate a bit more for an easier seal. I never like cranking on the nuts too much as they can distort and sometimes crack.
Nothing wrong with a q-jet???
Performer/Holley
Use a 1" or more spacer if possible with that combination. The carb butterflies stick pretty far down in the intake when open and hurt the transition flow.
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs |
You should have no issues Bob.
Carburetor building & modification services Servicing the Pontiac community over 25 years |
I did have to massage the center divider for butterflies a little but I think that was for the Q jet. I have that on now. Ran the Holley for a few years on the 81's 400 Performer
