541596 421 Super Duty McKellar #10 Camshaft
I recently acquired a NOS 421 Super Duty cam and thought I'd share a few pictures of this piece of Pontiac racing history.
Pontiac part number 541596, made by the Melling Tool Company who was the OEM supplier for all of the Pontiac cams under part number RPC-2. This is a solid lifter cam known as the 'McKellar #10 cam', named after Pontiac engineer Malcolm 'Mac' McKellar who was the camshaft designer during those glory days. The valve timing specs are pretty much identical to the RAIV '041' hydraulic lifter cam with 308/320 advertised duration, but with lower valve lift values of .445" intake and .447" exhaust using 1.65 rocker arms. The 421 SD engines running this cam were rated at 405 HP but were probably making closer to 500 HP. Ancient racing camshaft technology at its best, just leave it to Pontiac. Here are a few pictures of the long-duration low-lift cam lobes, first 2 pictures are the intake lobes. Exhaust lobes.
I ran one of those in college (and afterwards) for several years in a 64 389 "Mule engine", the original 389 TRI-Power engine was in storage. It has a marvelous sound to it. Instant rpm and held lash just fine over thousands of miles to Niagara Falls and other places from Michigan. I installed the 7/16 straight screw in studs in the heads I used. I also had a set of M/T Aluminum rockers with a bit more RA Ratio.
Tom V.
"Engineers do stuff for reasons" Tom Vaught Despite small distractions, there are those who will go Forward, Learning, Sharing Knowledge, Doing what they can to help others move forward. Last edited by Tom Vaught; 03-01-2015 at 09:43 AM. |
Interesting B-Man, thank you.
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. |
Tom, because of #10 long valve lift duration , were very high >12:1 compression required to maximize its performance?
Maybe "maximize its performance" but the Mule never had over 10.5 CR and ran great everywhere. Course I also ran a 4:33 Gear in the car too.
Tom Vaught
Back in the 90's we purchased a Melling 068 blueprint cam for a customer engine. It had lobes just like those, except the intake lobes flat was narrower than the exhaust[about 1/8" wide compared to 1/4" wide for the exhaust]. Years later, I saw another supposed 068 blueprint cam, but it didn't have the flat lobes. Now I wonder if the 068 cam we bought was boxed wrong and actually had this cam in it. It went into a stock 455 with 5C heads, tri-power, and 1.65 stamped steel rockers. It ran out of steam around 4200 RPM.
Has anyone ever Cam Dr one of those cams? Looking at the pictures it looks like it was designed with a huge amount of "dwell" over the nose.
Stan
Paul,
This is from an old H-O manual. Look at how flat the exhaust of the H (744) cam is. Stan
Those are the only two Pontiac OEM cams that I know of that have the flat nose. The H (744) looks even flatter. It's my understanding that the reason for this was that a fixed ramp rate was used on all their cams, so when the duration got big enough the lift had to be limited to not exceed what the heads could use - resulting in a flat nose on larger duration cams. The first cam that had a new computer profile was the T (041).
So, is the "S" cam, the 068?
9779068 Camshaft
Yes, and it has a flat nose lobe design that looks similar to the #10 421 SD cam. 'S' identifier stamped on the nose of the '068' cam. Intake lobe. Exhaust lobe.
Other McKellar mechanical cams
Good thread with accurate info. Nice close up pix of the lobes B-man. The only thing I can add is the specs for the other McKellar cams.
# - P/N - Int dur - Int lift - Exh dur - Exh lift - L/C - Adv - note 6 - 524886 - 283 - .406 - 293 - .406 - 114 - 2 - 1956 to 1962, lift w/1.5:1 7 - 535480 - 300 - .445 - 304 - .447 - 113.5 - 1.5 - 1959 to 1961 8 - 540233 - 308 - .445 - 312 - .447 - 113.5 - 1.5 - 1961 9 - ? - 308 - .445 - 312 - .447 - ? - ? - no production 10 - 541596 - 308 - .445 - 320 - .447 - 113.5 - 1.5 - 1961 to 1963 421SD 11 - 542992 - 312 - .445 - 324 - .447 - 113.5 - 1.5 - ditto, OTC 12 - 545319 - 308 - .445 - 324 - .447 - 113.5 - 1.5 - ditto, OTC Stan is correct as far as I know, i.e., the duration changes were due to constant lift dwell change over the nose. That makes for terrible dynamics, but it seemed to work. |
9779067 Camshaft
While we're on the subject of factory cams and how the lobes looked, here are some pictures of the 9779067 cam (273/289 advertised duration) which is the same profile as the 524009 'C' cam. The '009' cam is best known for its use in both the 1964 GTO 389 325 HP 4-barrel and 348 HP Tri-Power engines
'P' identifier stamped on the nose of the '067' cam. Blue-green paint swabbed on the back of the cam along with what looks to be a 'C' stamp that might be connected to the previous designation for this grind, perhaps a '009' camshaft identifier. Intake lobes with no flat across the nose. Flat nose exhaust lobes that look pretty much identical to the intake lobes on the '068' cam, 289 duration for the the '067' as compared to 288 duration for the '068' intake lobe.
Craig, would it be simple to state that extreme flat lobes substituted for high lift of today's cam design?
Conversation with Harvey Crane
68WarDog
In 1975 I had a conversation in my office with Harvey Crane (while he stilled owned Crane Cams) about the Pontiac cams and what he and his company could do for H-O Racing in the private label and custom grind arena. One of Harvey's main points during that discussion was that if one does a computer design and analysis (lift, velocity, acceleration and jerk) to produce a "smooth" profile, then one gets the extra lift "for free." This is due to not having "too much" deceleration on the opening side approaching max lift. The downside of course is that one has to check for coil bind, etc to account for the extra lift. All Crane's cams even in that era were computer designed. Harvey spoke well of the Pontiac 041 cam as being well designed and of course it had extra lift compared to the McKellar #10 even though the advertised durations were the same. |
Craig,
Did you ever have any dealings w/ Mr. McKellar, in the day??? Boy, I wish he was still around!, and many others!
I have a Performance Trends Engine Analyzer Plus and in the cam specs menu it has a setting for "Dwell Over The Nose". This cam is an example that would require entry of a number for dwell to get an accurate (for a sim) prediction.
B-Man, do you have a cam card with all the specs including dwell over the nose? I'd love to enter that cam in to my very limited library. Also, does anybody know how much dwell over the nose you see on a Stump Puller HR cam like SD sells? Performance Trends call these "Cheater Cams" and says the use of Dwell over the nose helps in racing classes where lift is limited.
Karl |
77 TRASHCAN
Just the fact that this cam survived in pretty much new condition in the stash of a long-time Pontiac enthusiast until I was able to buy it is pretty lucky in itself.
H-O Racing customer and NHRA Stock Class racer Billy Joe Moravitz in Texas did not have such a device so he used his "calibrated eyeball" to "measure" the dwell over the nose on cheater cams. Basically, it was "the fatter, the better." It seemed to work for him. |
