Old 03-08-2015, 12:33 PM
starlightblack's Avatar
starlightblack starlightblack is offline
Default '69 #48 heads on 1978 W72
48s on these .30 over pistons - block has been shaved 8-thousandths...compression ratio ballpark? pump gas or high octane?
lemme know - thanks in advance.
Old 03-08-2015, 01:18 PM
Alvin's Avatar
Alvin Alvin is offline
Suggestion: post and ask same Q in the "Pontiac - Street" tech section
http://forums.maxperformanceinc.com/...play.php?f=418
Old 03-19-2015, 12:49 PM
superdutybob's Avatar
superdutybob superdutybob is offline
Those heads on a stock 69 RAIII were 10.5CR. You have a little more dish volume in your piston with the 8 valve reliefs but you have shaved your block a skosh. My educated guess would be around 10.25, which to me is too high for todays gasoline. It would need to be cammed perfectly.
Bob Woodard
Brighton, MI
2012 SRT8 Charger - 12.70 @ 111mph
Old 03-20-2015, 10:34 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Heads probably not drilled for the alternator bolt if you are using 78 brackets.
Skip Fix
Old 03-20-2015, 11:18 AM
skunkwerks's Avatar
skunkwerks skunkwerks is offline
Default Been there done that.
You will need the 69/70 GTO bracket set-up to work on those heads. Kind of a pain to get it all to work on a Trans Am.
White/Blue 71 455 HO T/A Auto
Blue/Blue 71 455 HO T/A 4 Sp
White/Sandalwood 71 455 HO T/A 4 Sp
White/Black 70 RAIII T/A M21/373 (stripper)
Carousel Red/Black 69 GTO Judge 4 Sp
2002 Firehawk Red/Black 6Sp
Old 03-20-2015, 03:12 PM
Hmmm! I had a pair of 48s in a 78 T/A and I don't recall that problem at all. It has been 30 years though and I've slept many times since then too.
Bob Woodard
Brighton, MI
Old 03-21-2015, 11:07 AM
Skip Fix's Avatar
My SR 614s had the boss there to drill that extra hole, I don't think the originals did. I had one set of 16s a guy had drilled into the valve cover area but not straight. You could make a template for the holes off a late model head(or an E head) and then use a drill press/mill to get it straight and use some teflon sealer on the threads.
Skip Fix
Old 03-21-2015, 12:00 PM
2manyT/A'S's Avatar
As I recall.....1970 455 heads (cast#15) have the perfect chamber volume for healthy pump gas 400......
Eye Candy......garage band?
Go full screen & turn it UP!
Old 03-21-2015, 05:36 PM
FrankieT/A's Avatar
It looks like your pistons have the chamfer around the perimeter, which would lower your compression a bit. I run 12 heads which about the same as 48 heads on a .030 over 400 with flat tops on 92 octane with no issues.
Old 03-21-2015, 06:01 PM
Alvin's Avatar
1971 96's are workin' great on our '79 PWH
