Old 04-04-2015, 10:58 PM
Default Intake Manifolds - How Much Do They Weigh?
How much do the various factory and aftermarket intakes weigh?
A lot of us want to replace our heavy factory iron intakes with much lighter aftermarket aluminum intakes. Others have modified their factory iron intakes to remove unnecessary weight, often removing the iron front water crossover and substituting an aftermarket aluminum crossover. So for the sake of comparison it would be good to be able to know how much weight can be saved either by changing intakes or modifying them.
Weigh your intake on an accurate scale and post the weight here. Include a picture if you can.
After we start to compile a fairly complete list of all the most popular factory and aftermarket intakes I'll edit this post and make up a list for easy future reference.
Old 04-04-2015, 11:13 PM
Interceptor's Avatar
Interceptor Interceptor is offline
1972 cast iron intake -- I was surprised it weighed just 31 lbs. . . not like the "battleships" from the Buicks and Olds motors from that era.
The Following User Says Thank You to Interceptor For This Useful Post:
Old 04-04-2015, 11:20 PM
I've shipped a number of '67 -'72 iron Pontiac Q-jet intakes and most of them weighed right at 43 pounds packed up in the box, using a minimum-weight packing material (mostly styrofoam) that surely weighed less than 5 pounds. I would say those intakes weighed at the very least 38 pounds and likely a tad more, perhaps you could recheck the weight because 31 pounds doesn't seem right.
Old 04-05-2015, 12:06 AM
SS-TA SS-TA is offline
A 1973 cast iron intake (1st year EGR) - 47 lbs. A 1972 HO Intake without the crossover - 14 lbs.
Old 04-05-2015, 08:51 AM
71 T/A 71 T/A is offline
Weighed a 70s cast iron intake once, 42 pounds, aluminum Edelbrock Torker, 17 pounds.
Old 04-05-2015, 09:40 AM
Well, I'll never know now since its on the car.
Old 04-05-2015, 10:01 AM
Bobalong Bobalong is offline
I've often thought about ways to cut some weight from my 70 GTO. I like that I've kept it amazingly stock looking, although not numbers matching.
The A/C compressor, Intake, Spare Tire, Cast iron exhaust manifolds, And believe it or not, the combination of the Delco AM FM stereo & console mounted 8 Track combined with all the above are akin to having a passenger in the car at all times.
In reality, probably the spare tire & jack are the only things I would remove.
Stock is stock, it's the per pound price I pay.
Old 04-05-2015, 10:22 AM
Singleton Singleton is offline
Bare Tomahawk - 11lbs
69 4bbl - 38lbs
71 4bbl - 40lbs
76 4bbl - 43lbs
just for the heck of it, fully dressed 65 tri-power with carbs and lids, waterneck, thermostat, etc -59lbs
All weights done repeatedly on a bathroom scale, not sure of accuracy
66 GTO, 495, M22, Strange S-60 w/4.10
Sold new at Ace Wilson's Royal Pontiac
http://www.youtube.com/watch?v=cUHC-Z8xhtg
Old 04-05-2015, 11:03 AM
72projectbird's Avatar
I had to lift my 73 intake off the engine once in an awkward position. My god my back hurt after that.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 04-05-2015, 11:30 AM
Grand73Am Grand73Am is offline
1968 4 bbl, 40 lbs. (bathroom scale)
Steve F.
Old 04-05-2015, 12:11 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
I want to think my 73 SD intake weighed 47 or so. They had a much bigger EGR bosses on the bottom than the later 70 EGR intakes did.
Yea the Tomahawks are probably the lightest.
I'll weigh my M/T cross ram today for the survey
Skip Fix
Old 04-05-2015, 12:47 PM
69 4bbl - 38lbs
71 4bbl - 40lbs
76 4bbl - 43lbs
A digital bathroom scale should be pretty good as long as you're standing on the scale first holding the intake and after that getting on the scale alone and subtracting your body weight.
Old 04-05-2015, 12:54 PM
That's the way I did it.
Steve F.
Old 04-05-2015, 01:31 PM
Blued and Painted's Avatar
Blued and Painted Blued and Painted is offline
I was only able to remove 12 lbs by removing the exhaust and coolant crossover, and the unused bolt bosses.
Name:	marks motor 027.jpg
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk
Old 04-05-2015, 02:09 PM
That's an excellent weight reduction, taking an iron intake that started out near 40 pounds down to about 28 pounds.
Next time you have it off see if you can get it on the scale.
Old 04-05-2015, 05:18 PM
Skip Fix's Avatar
M/T shocked me was lighter than it feels 23.8 lbs
Skip Fix
Old 04-05-2015, 05:40 PM
1969GTO's Avatar
1969GTO 1969GTO is offline
Default Cast intake
Attachment 394618
I like your intake, got any more that look that good
color me gone
Old 04-05-2015, 06:17 PM
Tom Vaught's Avatar
Boost Engineer
That intake looks very familiar. Probably all of the extra weight comes from that "cross-over tube", Skip JK (;>) Its "brother" is sitting on the shelf.
It weighs 24 pounds with the same cross ram linkage and 50 pounds with 2 Holley 735 CFM dual quad carbs.
Tom V.
Old 04-05-2015, 08:22 PM
Skip Fix's Avatar
For an aluminum intake the Victor feel pretty heavy, alot of metal in it.
Skip Fix
Old 04-05-2015, 09:12 PM
Just put a Victor on my car the other day. Didn't think to weigh it first though. It felt quite a bit heavier than the Tomahawk that it replaced
