Old 04-11-2015, 04:19 PM
Transamric's Avatar
Default distributor hold-down clamp and bolt
Help out the old brain here Am I correct to remember that the distributor hold-down clamp and bolt were not on the engines when they were painted? Therefore, the correct finishes would be bare metal?
If it matters, this 400 I'm working on right now is a '75, so it's an HEI.
Old 04-11-2015, 07:50 PM
Norwood's Avatar
Norwood Norwood is offline
for some reason I'm thinking dark phosphate
Old 04-14-2015, 06:49 PM
Transamric's Avatar
Phosphate for the bolt, but on the clamp too?
Old 04-14-2015, 07:18 PM
2manyT/A'S's Avatar
I'd say natural.....with a dash of feO2
Eye Candy......garage band?
Go full screen & turn it UP!
Old 04-15-2015, 12:21 PM
Aus78Formula Aus78Formula is offline
Might be like apples and oranges, but by 77 when the olds engines appeared, the dizzy was in place at time of paint and over spray covered it too.
Old 04-15-2015, 09:13 PM
Held for Ransom's Avatar
Held for Ransom Held for Ransom is online now
At first I was going to say, no paint on distibutor or clamp other than here.
ID:	395521   Click image for larger version
ID:	395522   Click image for larger version
Old 04-15-2015, 09:19 PM
Transamric's Avatar
Thanks. Mine has those blue & black splotches too. I also found it odd that in addition to the typical stamped part number & date code, there is an aluminum band snapped around the dist body at the base with the same info stamped into it.
Old 04-15-2015, 09:21 PM
But then I realized what I thought was an 5A21 was more than likely a 5H21 (as in '85 or '95), car was shipped 1-10-75. And the module was a replacement, as well as plug wires. Natural steel on clamp, but backside looks to have paint on it. 2 lock washers had me thinking the machining wasn't deep enough on the hole, but who knows.
ID:	395525   Click image for larger version
ID:	395526   Click image for larger version
ID:	395527   Click image for larger version
Old 04-15-2015, 09:30 PM
And the stainless band was missing too. Man, I missed a lot on this one.
