Old 05-27-2015, 05:42 PM
John Milner's Avatar
John Milner John Milner is online now
Default '74 GTO headers round port heads
What is the best fitting headers for these cars that are running round port heads? I am running a 4 speed as well. I would prefer something that wouldn't make changing the oil a hassle, changing starter a hassle and would not rub against clutch linkage. I would certainly prefer to run the long branch manifolds but I'm not sure when or if they are going to be reproduced. Any suggestions?
Old 05-27-2015, 05:59 PM
ponyakr's Avatar
ponyakr ponyakr is offline
I think those cars use the same headers as the 1st gen Birds. And Most guys say the Dougs fit best.
Looks like the part number is D568. They are about $800 coated.
http://shop.dougsheaders.com/doug-s-...l#.VWZJXNJViko
http://www.summitracing.com/parts/dou-d568
The D568-B are painted black.
http://shop.dougsheaders.com/doug-s-...l#.VWZJ8tJViko
http://autoplicity.com/8259896-dougs...exhaust-header
And the D568-R are raw, which I assume means no paint or coating, which makes 'em a bit cheaper.
http://shop.dougsheaders.com/doug-s-...l#.VWZKLNJViko
http://www.amazon.com/Dougs-Headers-.../dp/B0050SG4CU
Old 05-27-2015, 07:07 PM
ponyakr's Avatar
Default Oil Filter
If I'm reading the Dougs site correctly, you need one of the smaller diameter filters, such as the Wix 51522 or NAPA 1522.
http://www.summitracing.com/parts/wix-51522
http://www.oilfilter-crossreference....vert/NAPA/1522
Old 05-27-2015, 10:53 PM
se428bandit's Avatar
se428bandit se428bandit is offline
I'm about to change from to D-ports to Edelbrock roundports heads on my '72 Ventura. I have heard good thing about Mad Dog headers. I'm planning on ordering my headers next week. http://maddogheaders.net/products/pontiac
Old 05-28-2015, 09:52 AM
Rob B's Avatar
Rob B Rob B is offline
STAY AWAY FROM THE HEDMANS!!! They suck suck suck. You have to use headers for a first gen which uses the same subframe as the x bodies. Hedmans will need major "massaging" around the gearbox and rag joint as well as around the motor mounts (if you use a solid mount or ploy mount). I had mad dog make my current headers on my 74 in a 2"pipe. I eliminated the use of the stock mounts on my car and converted to a rack so they fit fairly easy. I didn't have to put one ding in them anywhere to get them on and they both come out underneath the car pointing straight compared to the goofy angle the Hedmans do. Mad Dogs are well worth the money. Stay away from Hedman!
74 GTO Bracket/Street car and another 74 for the wifey to race with!
70 GTO 400, 4 spd, #'s matching and a little to nice for me to own.
Friendship is like peeing your pants..everyone can see it but only you can feel the warmth!
Old 05-29-2015, 08:15 PM
ponjohn's Avatar
ponjohn ponjohn is offline
I had Maddogs on my ventura, fit very nice.
Old 05-31-2015, 09:58 AM
Called Mad Dog to order my headers and found they are moving to Georgia. So it's going to be 12 weeks on a set of headers.
Old 06-01-2015, 08:41 AM
Rob B's Avatar
Unless Hedman made some serious changes on the driver side tubes, You'll have issues with the gear box, The rag joint, motor mount, and you'll have fun installing your starter which better be a mini. Passenger side is minimal.
