EFI Tech All things EFI and making classics modern!
Old 08-14-2015, 12:05 AM
Nicks67GTO Nicks67GTO is offline
Default New self learning EFI at half the price....
I posted this here because its definately a street car thing and the boost section dosent get much traffic.
Theres a company called FITech .They are making self learning EFI setups for 600hp-less engines for 995.00 or 250-1200hp engines for 1495.00. They control timing and do everything the high dollar setups do, use factory GM sensors and injectors and the guys building it are supposedly really top notch fellas from the things ive read around the net. Theyre also self contained, no external box and minimal wiring. The handled unit used to set it up is removeable after install. This might change everything. A guy on PT.com installed one on his wifes auto X mustang and said it works flawlessly. Heres the link to the company....who wants to be the guinea pig??
http://www.fitechefi.com/
Heres a video of Jeff Smith installing one on his elcamino
https://www.youtube.com/watch?v=SsscxiUga5Y
-1967 GTO HO Restomod. PKMM 433ci, SilverSport T56 Magnum 6spd, Moser 9", SC&C and a bunch of other pro touring goodies
- Build Thread
http://forums.maxperformanceinc.com/...615847&page=23
Old 08-14-2015, 08:01 AM
grivera's Avatar
grivera grivera is offline
I've done a bit of reading on the sub 600 hp system and spoke with Ken at FiTech. He indicated FiTech produces many of the components for OEM efi systems, many of which are used in GM vehicles. This along with their business model keeps their cost down. At this point, they have about 500 systems in circulation and a claimed 100 % success rate. I am seriously considering the conversion once I get over the start up of the new engine.
A couple on this board have already made the leap:
http://forums.maxperformanceinc.com/...ghlight=Fitech
Will Rivera
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears
Old 08-14-2015, 10:02 AM
Formula8's Avatar
Formula8 Formula8 is offline
Big question for the Pontiac crowd will be can this be used with a drop base air cleaner or stock air cleaner without the use of spacers? That FPR looks awfully close as do the fuel lines once you put fittings on them.
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi.
Old 08-14-2015, 10:18 AM
David Jones's Avatar
VERY interesting. Beyond the $1000 for the basic 600hp system I wonder what else is required? New fuel pump, fuel lines etc?
Old 08-14-2015, 10:22 AM
grivera's Avatar
Here a great write-up on a Corvette forum with a factory looking air cleaner:
http://www.corvetteforum.com/forums/...fi-review.html
Will Rivera
Old 08-14-2015, 10:49 AM
Formula8's Avatar
Thanks for the link. I read the write up and he used a 1/2" air cleaner spacer as I had suspected would be necessary. That may be a deal breaker for some.
Old 08-14-2015, 11:03 AM
grivera's Avatar
In my case I'd also keep the factory intake and use an adapter so between it and the air cleaner spacer, I'd be looking at about 1.5". Not sure if the TB itself is shorter than a quadrajet...http://www.fitechefi.com/virtualoffice_files/30001.PDF
Will Rivera
Old 08-14-2015, 11:39 AM
Good write up. After reading it I sent the mfg'er an email asking a couple of questions.
Old 08-14-2015, 11:49 AM
grivera's Avatar
It requires an efi capable fuel system and lines capable of efi pressure. They also market their Command Center, a self contained unit that has it's own fi pump. The CC is supplied by the stock fuel pump and provides the high pressure fuel to the TB via high pressure lines. This is a great alternative to those with a carb style fuel system. http://fitechefi.com/default.asp.pg-...lCommandCenter
Other than that, it looks pretty straight forward since the efi TB package also has a built in fuel regulator.
Will Rivera
Old 08-14-2015, 12:12 PM
Definitely a new system to keep an eye on. I was considering the Holley Eliminator system for my Catalina, but this unit looks like the way to go IF they prove to have long-term reliability.
Dr. Thomas Sowell
Old 08-14-2015, 12:45 PM
JLMounce JLMounce is offline
Will be keeping my eye on this. I've got an old offy dual quad manifold, that dual tbi setup looks intriguing!
-Jason
1969 Pontiac Firebird
Old 08-14-2015, 01:37 PM
Formula8's Avatar
Yeah, me too. I'm converting back to an iron intake to bring the rpm range down a bit after installing the SD ported KRE heads. Edelbrocks q-jet adapter is 3/4" high and my Holley is 3 1/4" like this throttle body. The float bowl screw is 5" from the center which is the same as the FPR on this TB. With my drop base, I need a 3/8" air cleaner spacer to clear my carb. So bottom line is that this should fit pretty much the same as my set up. Maybe some dimpling on my drop base which would not be much of a problem.
Old 08-14-2015, 04:37 PM
TCSGTO's Avatar
TCSGTO TCSGTO is offline
Since there aren't bowl vents to contend with could the air cleaner lid be closer to the throttle body and still work properly?
68 GTO,3860#
13.86 @ 100
Old combo:
New combo:
636HP/654TQ
1.452 10.603 @ 125.09
Old 08-14-2015, 05:01 PM
It looks like they are back-ordered on the base kits. I'm waiting for a response back from them about their timing control support for different dizzies. They are stating you just need a two wire dizzy fired by a coil, where kits like the Terminator require a dual sync dizzy.
If my current distributor can be locked out and fired by this unit, I'll probably purchase it next week.
-Jason
Old 08-14-2015, 06:49 PM
mklinger's Avatar
mklinger mklinger is offline
In order for their system to control spark you need a non-HEI distributor other wise the curve in your dizzy is in control. So, go crank triggered ignition or what other options are their?
There are no problems..only solutions.
Old 08-14-2015, 06:52 PM
Their FAQ states you need a 2 wire type distributor. The specifically mention MSD as well as Summit and Jegs branded models. They also state no CD box needed.
I'm currently running a Mallory Unilite with a ProMaster coil. It's been a good distributor, but it's a model that does not contain or have provisions for a vacuum advance. If I can lock that out and have the ECU control the coil, that would save me almost $600.00 over a FAST duel sync and MSD 6AL box.
-Jason
Old 08-14-2015, 07:28 PM
Gator67's Avatar
Gator67 Gator67 is offline
Wonder if the TB is shorter than the Fast EZ EFI 2? Trying to fit everything under a stock formula hood with factory appearing air cleaner.
Old 08-14-2015, 09:23 PM
Sirrotica's Avatar
The configuration of the TB reminds me of the Carter 4BBL. AFB, AVS, Thermo Quad models, as far as dimensions and layout. The internals are where the float bowls would be on a Carter.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 08-14-2015, 09:37 PM
455 pontiac's Avatar
455 pontiac 455 pontiac is offline
I installed the fast ez efi on my 69 lemans several years ago. With the stock tank I always smelled a lot of fumes. I ended up getting a tank from tanksinc. with the pump in tank, very nice tank and from the rear of the car it looks stock. Also frangola has some nice push lock hose and fittings. hope this helps Jeff
1969 LeMans..Liberty Blue
2001 WS6..Sunset Orange
1973 Pro Street Firebird..Lucerne Blue
Old 08-14-2015, 11:32 PM
Squidward's Avatar
This setup also intrigued me, but as others stated, wanted to hear some real world reviews on reliability before popping on it. Besides, I don't have an engine ready quite yet for it to feed.
I sent an email a little bit ago about using an HEI running an MSD6AL. no response yet. When setting up to run with an MSD box, you gut the module out of the disty, and are just using the HEI for its magnetic triggering. It seems like it's doing the same thing as the RTR, since the magnetic trigger fires the box, and the box fires the coil. I guess I'm not seeing why a gutted HEI wouldn't work. I understand that the HEI cap isn't made to be indexed, but that could be overcome somehow.
