I`m trying to find out if a Victor intake would fit under a 69 Firebird hood with a 2" cowl. if so what type of air cleaner base would I need?
pics of my cowl hood below
69 Firebird 472, Bullet SFT, KRE 85cc, Victor, 850xp, TH400, TSP 9.5" 4800, 3.90 10 bolt, Viking DA rears, QA1 single fronts, 3558lbs. best to date 11.14@120 |
Yes it will. It actually will fit under a stock flat hood. I had one with a nitrous plate and a 850 carb, moroso drop base cleaner and a 2" filter all under the stock flat hood. A 2" filter may be a bit restrictive for all out racing and max hp but I removed it when i was at the track racing. On the street a 2" filter is quite enough for what you need there.
https://www.facebook.com/photo.php?f...type=1&theater Last edited by Engo; 09-17-2015 at 02:49 AM. Reason: s |
When you make the swap be ready to use two stacked valve cover gaskets and hold down studs if your valve covers are the type with a lip to hold the gasket.
I had a vic on my 69, Street strip only. By the way, Who makes that hood? Nice car.
![]() Quote:
the hood was made by someone over here by taking a mold off my original steel one, then making the cowl to follow the shape of the original lines. it was a one off for me as the guy used to race with us and did it in his spare time. I do have the finished mold in case anything happens to this hood.
U need at least 4' above the carb to run efficiently.
You're gonna need the extra clearance your custom hood provides
1969 Firebird, Tx3-455/468 machined by CVMS E-heads by Dave Wilcox/Comp Cams 300B-6 flat solid 850DP on E-85 by Eric Niefert/T2 1" plastic spacer T-400/PTC 4000/390's/30x9 Hoosier radial slicks,#3400 1.38 60' 6.32 @ 108 MPH at Northeast Dragway NC 5/23/15 (9th pass on new engine) https://m.youtube.com/watch?v=ePCu2v...ature=youtu.be 1.37 60' 6.26 @ 109 half track, 9.86 @ 136 1/4 mile, #3350 11/26/16 at Richmond Dragway (125th pass on new engine) |
