904 Bushed Lifters Suggestions
After losing a Comp solid roller lifter yesterday, leaning towards going the bushed route and possibly upgrading to the larger 904. Doing a search on here, looks like the Isky has been the brand of choice. Is this still the best lifter to go with? This is in a street car that sees a lot of miles(drag week) and plenty of track time too.
65 Lemans Street Car - 521, T400, 3.70 9". 10.13 @ 135. 3770 lbs. Drag Week ‘14, ‘15, ‘17 63 Lemans Race Car- 8.81 @ 151, 5.60 @ 123(SOLD) 67 Bonneville ragtop 74 Firebird - 455, e heads, TK0600 in process |
Isky gets the kudos for developing the bushing lifter. I went with Crower because I had a set with needles that I had them convert to bushings. I just put a set of Morel .904 bushing lifters in the War Chief, they look to be a quality piece.
I.had crower convert my needles to bushing also. Keep in mind that slowbird has dyno proof that you will lose some power. But it's probably worth some piece of mind.
1969 carousel red firebird 455, richmond 5 speed 1964 540 gto 1971 lemans sport convertible 1972 Maverick under slow construction |
We use Crower Endua-max, (a bushing lifter) in the .937 size in the nitro engine. They are really tough and can be rebuilt, which we have done. Many on this board have used Isky with great success and I have no personal experience. Part of the reason is I never had the opportunity. As I have mentioned on this board many times, to us, an interest in a project and great personal contacts are an important part of our program. At the PRI on two separate occasions different years, we were met with a very cold shoulder by Isky. Lots of questions about why we were running a Pontiac engine, how they were junk, would never hold up in our application. All the typical crap that really turns me off. Crower was open and interested. That's a big reason why we use their parts. They also offer great service and have quality parts.
Jesel makes a lifter for pontiacs. I use to break crowers ever 3-4 passes. I ran the jesel 4 years with zero issues.
Thanks guys. I've got a set of Crower 842 lifters that could be rebuilt. Maybe I'll call them to see how much to convert them . Cam is only 730 lift with 245 on the seat.
Want to say it's about 550 hooter
I have posed this question on Speedtalk with no answer.The NASCAR Toyota Cup engines run Jesels with needle bearings.My thought was if the bushings were better they would run them?Maybe not because of a small loss of HP?Tom
I have Isky .842s EZRoll EnduraMax. I have had them rebuilt once with needles and this last time with the bronze bushing. Never a problem. No lifter bore bushings either. Sizeable cam with 1000 psi springs. Next block rebuild I would like to go with the 904s or 937s, with a bigger cam core.
1978 Pontiac Grand LeMans.......out next year Previous - 2001 Jerry Haas-built P/S Grand Am - former WJ car, Hoffman Racing 535" IA2, Tiger Heads/Intake, Single Dominator, PG Best ET: 7.776 @ 175.94, 1.096 60', 2375 lbs. |
Just called Crower. No more spring or cam that I run, they recommend bushing my old set. Looks like I'll go that route. $480 to do them.
John, are the Jesel lifters you run keyway or tie-bar? Also what diameter? That's fantastic service life. Would you be willing to share approximate open/closed spring pressure? Also approximate max RPM and valve lash you run. We have found wide lash, (over .022-.023") kills the lifter wheels pretty quickly. We only run .014" cold on the funny car and have had much better luck.
I use many products from Comp Cams, but I will not use Comps roller lifters.
Calvin Hill Hill Performance 708-250-7420 |
Very impressive lifter life under those conditions. Obviously, you have great harmonic control to run the high RPM's with what must be a long push rod. We have been told the biggest issue for us on nitro is the initial load when the exhaust valve is cracked open while cylinder pressure is still very high due to the slow extended burn time of the nitro. We had to go to steel rockers for this reason also. We use all custom Jesel rocker gear, I will certainly talk to them at PRI. Our current lifters have been fine when we can keep the crap out of them from other catastrophes. Thanks for the info.
I had mine converted. Like said I only have about 40 passes so far. Over the nose is 1,000+'so time will tell. I hate needles 😏
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
So does Comp offer a similar mod for their needle lifters at this time?
Tom V.
These are fairly new from Comp. Thanks, Gary in N.Y. P.S. Not sure about having the original roller style changed to the bushing setup. Simple call to Comp would tell! |
Comp can't be getting very good reviews when the "needle" solid roller lifters are failing on a deal like Drag Week. Drag Week is only a few actual drag strip passes at a handful of strips and a bunch more miles at less than typical (75+ mph) normal street driving today.
Tom V.
I think Johnson makes the Comp lifters.Tom
Tom S, I can see where Johnson might make the Hydraulic Roller needle bearing lifter.
Was not aware that they were making the solid cam roller lifter also. Tom V.
