Has anybody tried the new oer brand tachometers for the 2nd gen trans am they are on summit sit for like 259.00 and look like original
Do you have a link
Its ok to giggle and snicker, Dont laugh and point |
I installed the OER 6K tack and 160 speedo and they look great and are working aw-sum..
I bought them from Classic Industries. Installed in a 76 Transam.. http://www.classicindustries.com/pro...s/6497947.html http://www.classicindustries.com/pro...s/5659065.html Charles
68 Firebird. IA2 block, 505 cu in, E-head, Solid roller 3650 weight. Reid TH400 4:11 gear. 29" slick. Best so far 10.12@133 mph. 1.43 60 ft. 76 Trans am, TKX .81 o/d, 3.73 Moser rearend, 468 with KRE D-ports, Doug headers, 3" Exh. Last edited by chuckies76ta; 10-25-2015 at 09:19 PM. |
take a look at these,,they are mine..theres none better in my opinion used, unless you had a set restored and spent a lot of money...slip in a nice 160 speedo and you would have something special
http://www.ebay.com/itm/121793218579...84.m1555.l2649
Mark.. The Goat whisperer "I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered." ![]() |
I rebuilt an original tacho for mine with a new coil, only to damage the calibration of the needle. I grabbed a new OER unit, and unlike good used tachos, these come with working clocks that are now quartz like 79-up models. Fantastic repro. I picked mine up from Firebird Central about $50 less than the Classic price. Cost to post was double that so not a cheap item.
chuckies76 , why did you replace the tach in your T/A, I understand why you installed the 160 speedo but was the original tach bad?? If so what have you done with the old one. Do you still have it & if so do you want to sell it ???
Marks junk I have bought 3 tachs over the past YEAR and all look like new but all of them don't work right the circuit board is what goes bad and until someone makes new boards for them ,then are all JUNK and I am done spending $$ on them ....now that we have new OER TACHS available for 250.00 is a no brainier
You know, instead of posting to some guy who's only interested in selling his junk to which you and I both agree, you could at least Thank the people who took the time to provide feed back and actual information.. fwiw
My .02 Charles
![]() Quote:
Thanks Charles
Chuckies76ta are you serious ?? thanks so much for your input, way to go , you the man , I bow to your better judgement. Is that enough ??
seems like that tach isn't available for 79s
same for temp gauge too that sucks they do look nice has anyone had any factory gauges restored? if so, by who? and how are they looking/working now? i'd love to place the tach in my 79 with an 8k but seems like its not a simple plug and play deal ![]() |
![]() Quote:
Tach I think are easy to swap the 160 speedo has a different brake/seat belt light than my 78 did and for sure the 81.
One guy over on Nastyz28.com I think Gaugemarks restores them and can paint the 160 on the face with the correct brake/check engine lights that later TAs had.
redline gauges in kentucky is a good guy...he can put modern movement in about anything GM..and likes to reface stuff that never happened..like 240 speedos etc..hes a full gauge shop..
Redline in KY for sure. Decent guy, rapid service- but then I knew a guy who knew a guy.
He is not impressed with the repros, the stuff inside makes him hurl. |
