Motor mounts
On a 67 gto frame are the motor frame mounts the same as for a 72 lemans
If the Lemans was a 350 or 400 car they should interchange with the 67 GTO frame side mounts.
What about a 389
According to Ames the same frame mounts are used for 64-72 except X-bosy and 455CI motor. They are side specific as one is different from the other.
https://secure.amesperf.com/qilan/De...A&web_access=Y
Remember no one is perfect. Everyone's butt has a crack in it! |
All will interchange from '64 -'72, both the frame stands and the rubber engine mounts.
All engine displacements will fit these, 326, 350, 389, 400, 421, 428, and 455. The '70 - '72 455 cars originally used a special wider mount and matching frame stand, but they're not necessarily needed to swap in a 455.
