Just wondering if anyone know where I could order an adaptor plate to mesh this TH350 to this 336
I know I can make one but if I can order one it would save a bunch of time. Heath
"If you aren't first, your last." Ricky Bobby 2006 |
Butler has a plate for the 61-64 engines that should work .It has the starter mounting you will need and will space the trans correctly for the longer 63 326 crank.You will need to machine your converter to suit the early crank.If butler cant help PM me.
Right on, thanks for your help!
For $250 it doesn't make sense to try and make one, http://www.butlerperformance.com/pro...btcp010004.jpg
Oops forgot to say you also need 1/4" thick washers between flex plate and the converter.
Heath, there is an adapter for sale on Facebook for $100. It is in Marion Iowa!
