Old 01-10-2016, 11:32 PM
421-6speed's Avatar
421-6speed 421-6speed is offline
Default Long Branch D-Port Factory Headers 1960-1970
I have a set of Pontiac Long Branch D port Factory Headers for sale. These are the good ones made in USA. I did install them but they were never run. I did not use gaskets and still have them new in the package. I had them ceramic coated gray as well as all the hardware silver. 650.00 shipped in the lower 48
I also have the oil filter adapter 65.00 shipped. I did paint it Pontiac blue and it was installed and primed engine but not ran.
Or 700.00 for headers and oil filter adapter shipped.
Long Branch D-Port Factory Headers 1960-1970 Big Car ( Catalina, Bonneville) Plus Many Other Applications.
Pair left hand and right hand D-port Long Branch Factory headers. These will fit the 1960-1970 big car Catalina/ Bonneville,67-69 Firebird,71-77 Ventura, and 69-72 GP. These castings have exact external configuration as originals and have precision port and runner detail. These Long Branch have better flow and pulse segregation than originals or competitors. Collectors are 2.50" id. Along with greater flow, you can run 2.25" or 2.50" exhaust pipes. 2-correct part numbers verisions are avaiable. 1960-67-LH 9779495,RH 9779493 and 1968-69- LH 9779495 and RH 9791607. Each requires 2-bolt flange (PFL-3 sold on page). Other items PH-5 Hardware installation kit, D-port exhaust manifold gaskets on page @ $29.00 set. The big cars will require the oil filter adapter # POF-1 or the Firebird, GP,and Ventura will require POF-2 oil filter adapter. Optional Ceramic Coating; Both castings are port matched to to Pontiac blueprint then thermal barrier ceramic coating is applied and cured on the interior and exterior. Choice of Silver or Gray. 3-year Guarantee. Will not burn off, fade or peel. Reduces header temperature 40%. Silver is Chrome-like. Gray looks stock.
Thanks Dan
360-509-8182
Name:	Ram Air Long Horn manifolds 1.jpg
ID:	417868   Click image for larger version
Name:	Ram Air Long Horn manifolds 2.jpg
ID:	417869   Click image for larger version
Name:	Ram Air Long Horn manifolds 3.jpg
ID:	417871   Click image for larger version
Name:	RAM AIR oil Filter addaptor.JPG
ID:	417872   Click image for larger version
Name:	Bellhousing installed.jpg
Old 01-10-2016, 11:36 PM
421-6speed's Avatar
A few more pics
Name:	Longhorn Manifolds 1.jpg
ID:	417877   Click image for larger version
Name:	Longhorn Manifolds 2.jpg
Old 01-11-2016, 04:17 PM
421-6speed's Avatar
These manifolds are the Ram Air manifolds.
Old 01-11-2016, 09:39 PM
ClassicDriverMan's Avatar
ClassicDriverMan ClassicDriverMan is offline
PM sent.
Tribal Tube Header Rip Off Victim. Ordered March 27, 2012. Told 3-4 weeks. Still waiting
Old 01-11-2016, 09:55 PM
421-6speed's Avatar
PM answered
Old 01-11-2016, 10:23 PM
PM backed...
Deal.
Old 01-12-2016, 01:51 PM
421-6speed's Avatar
Sale pending
Old 01-14-2016, 02:10 AM
421-6speed's Avatar
Still have the oil filter adapter 65.00 shipped. I did paint it Pontiac blue and it was installed and primed engine but not ran.
Old 01-14-2016, 10:45 AM
grivera's Avatar
grivera grivera is offline
Are these originals or repros as in link? http://www.ramairrestoration.com/lb-...y-headers.html
Will Rivera
‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded)
Old 01-14-2016, 10:12 PM
421-6speed's Avatar
Yes that is them in the link.
Thanks Dan
Old 01-25-2016, 12:02 AM
421-6speed's Avatar
ttt
Old 05-13-2024, 01:27 AM
Odinturner Odinturner is offline
Default Long branch
I am happy to buy these if they are still available. Thanks, Odin 360-644-3930
