Pontiac - Street No question too basic here! |
View Poll Results: Type of Distributor/Ignition in Your Street Pontiac | |||
Factory Points Distributor | 48 | 16.55% | |
Pertronix Converted Points Distributor | 42 | 14.48% | |
GM HEI Distributor | 99 | 34.14% | |
Small-Body Converted HEI Distributor | 8 | 2.76% | |
Mallory Unilite Distributor | 18 | 6.21% | |
MSD Ready-To-Run Distributor | 43 | 14.83% | |
None - Coil Over Plug | 1 | 0.34% | |
Crank Trigger | 2 | 0.69% | |
Magneto | 1 | 0.34% | |
Other | 28 | 9.66% | |
Voters: 290. You may not vote on this poll |
Poll: Type of Distributor/Ignition in Your Street Pontiac
What kind of distributor or ignition system are you all running in your street Pontiac?
Some of the choices posted are a bit exotic or more race-oriented, but I know there are some of you here who do like to push the envelope a bit. Here are the poll choices: 1.) Factory Points Distributor 2.) Pertronix Converted Points Distributor 3.) GM HEI Distributor 4.) Small-Body HEI Distributor 5.) Mallory Unilite Distributor 6.) MSD Ready-To-Run Distributor 7.) None - Coil Over Plug 8.) Crank Trigger 9.) Magneto 10.) Other Thanks for voting! |
Bart,I have the pertronix in stock dist in 2 cars now but have had it in virtually all my past cars.The 4 cyc has points the 421 SD 63 has a Hi6 with a mag pickup.I have also used one of Dave SB hei conversions in a stock dist.Tom
Pertronix in my 68 Firebird 350 and just converted (yesterday!) to pertronix in the 68 Lemans OHC 6.
I have a DUI - a variation of choice #3. Love it!
1965 Pontiac LeMans. M21, 3.73 in a 12 bolt, Kauffman 461. |
The MSD has been perfect for 4 years now
color me gone |
My original been fine for 45 years now.
71' GTO -original 400/4-speed/3.23 posi 13.95 @ 102.1 on street tires @ 4055lbs. ‘63 LeMans- ‘69 400 w/ original transaxle. 2.69 gears. |
Stock points distributors in both.
1961 Corvette 4spd. 1969 Chevy K5 Blazer - currently restoring |
Unilite since 1985. No bad modules.
Pertronix pickup conversion in a stock points dist for 15 years with MSD 6AL
Old HEI ,BOP pol gear,mechanical advance limited to 14 degrees,MSD blaster coil,MSD 6al
I've re-fitted HEI's into all my old GM cars. Zero failures. And one less thing to stress about.
Mechanical advance stop installed with a modified adjustable vacuum can.
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk |
Was running just a mechanical advance MSD Pro Billet with a standard 6AL ignition box. But now going with a locked out distributor and a programmable 6AL box to have full control of the ignition curve.
I have an HEI rebuilt with a H-0 Racing distributor kit with their 14° vacuum advance in my 1971 GP Th400, and have original points in my 1962 Catalina 389ci with the slimjim, both work seamless!
Jim Moshier 1971 Grand Prix 462ci SD Performance 6x heads 1962 Catalina 389 1968 Firebird 400-455 I haven't decided "If we ever forget that we're one nation under GOD, then we will be a nation gone under." - Ronald Reagan |
HEI done By Cliff with Mallory #699 module with built in Rev limiter
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's |
Dave's Small-Body HEI
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears '69 LeMans Vert, 350, #47 heads: Non-running project |
D.U.I great GM style dist made in Memphis TN, love it.
Coil over plug
'71 Holden HQ Monaro - 3850lbs race weight, 400c/i - 11.4 @ 120 '66 Pontiac GTO - 389, 4 speed street cruiser |
Hei with an advance kit, adjustable vacuum canister, with a msd blaster coil and 6al box for me but soon will be msd distributor.
I have a Mallory magnetic ready to run which wasn't a choice so I chose MSD
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi. |
Aftermarket HEI disty, with module removed, triggering MSD 6AL.
I've used the Pertronix before, too.
