#81
The track is the best place, numbers on a piece of paper mean very little.
#82
"Measuring dyno results from one facility to another is always going to be like measuring apples to oranges to some degree, regardless of the correction factor”
"Finding a reliable dyno shop takes research, patience and sometimes a little luck." http://www.enginelabs.com/engine-tec...he-first-time/ Take your engine to USA Racing Engines, aka "The WOP Shop", in Houston Texas. Their engine dyno is located near sea level, and take it there on a cold dry Winter day .
#83
When I built an engine for EMC we dynoed it at the shop I now work in[didn't work there then]. That dyno showed a peak HP of 571 from 6100-6500 RPM, and around 540 FT. lbs.. It ran flawlessly. Once at the EMC The funding guy of the engine made a call to change plug wires to the sponsored plug wires. 3 of them were bad. On the DTS dyno at EMC, this engine had a terrible miss, but still managed to crank out 541 HP, and 500 ft. lbs. on 5 cylinders. It was good enough to place us in 34'th place out of 50. Not bad for 5 cylinders. That shows how much dyno's can differ. If we had left the MSD wires on it, it probably would have cranked out 650 HP on their dyno.
#84
When I had my engine dynoed at BES racing , they just had the dyno software updated about a week befor and said it was running very conservative . Tony said all of their known combo type crate motors were down on power . So even a software change on the same equipment will juggle the numbers. But how much he didn't say . Has anyone compared dynoed ? Are we talking 10-20 hp or 30-40 !?
When I wore a younger man's clothes |
#85
A buddy of mine builds dirt track engines and owns his own dyno. It's a Stuska and it's where I dyno all of my stuff.
He had a customer dyno there, then dyno at a Superflow across town and there was 80 hp difference between them. |
#86
Because I'm of this mindset does this mean I'm against increasing or improving performance? Hardly. I'm just trying to stay in line with the intent of the original posters inquiry, simply that and nothing else. Stone-stock 400 build looking for a cam to compliment that, remember? Higher-end street performance engine builds very well may warrant playing with cam advance to find the sweet spot, just like a Super Stock racer might do along with trying a multitude of different cams, lash settings, converters, rear gears, etc to get the edge on their competition. Quote:
Where did you see anyone jumping on you for your comments, and saying "that's not how the factory did it"? Nobody is serving up any Kool-Aid here. Nobody expects that anyone will 'follow' along with some imaginary group. We're all here to freely discuss our ideas, respecting each other's point of view and also treating each other with the same respect that we all deserve. Quote:
Cliff's work in the industry speaks for itself, whether or not you or anyone else agrees with his methods. How about you post some tech threads of your own to showcase your engine building prowess, and let the forum members make their own assessment?
#87
"This is the Pontiac Street forum, what applies to race engine builds doesn't necessarily apply here." Please explain what that means if we can't discuss the things we were discussing? Nobody was talking about vacuum pumps, Super Stock engine builds, or anything of the like.....we were talking about camshaft selection, lobe separation angles, and things that are important for a proper street build. Please inform me on what my agenda is, because I certainly don't know myself. As far as posting some tech threads of my own, I thought I've been earning my keep so far by helping guys out in various threads concerning measuring for bearing clearances, filing piston rings, a little bit of this, a little bit of that. Otherwise, if you're concerned about my prowess or experience level, just Google my name or my business name. I'm not sure what Cliff's problem is. Maybe it's because he's been used to "running the show here" and now that someone has questioned his word, he feels the need to go on defense. But if you don't think I've been "jumped on" for suggesting something other than factory style thinking, then go back and read through the dozens of pages that have been generated over the past few days.....because I disagree. The first time I disagreed with Cliff publicly, I got probably a dozen emails and PM's about how many times various engine builders have come here and disagreed with him. I haven't been here long, but obviously this happens from time to time and the new guy gets tired of arguing so they just start letting it slide. I'm not going to let it slide... Last edited by blykins; 04-02-2016 at 07:38 PM. |
#88
The smiley faces don't soften it up much.
#89
Blykins takes hits at Cliff anytime he can. Even on a thread about connecting rods. It gets old...
Sent from my SAMSUNG-SM-G900AZ using Tapatalk |
#90
My agenda is stating the obvious?
#91
Your a punk that stays in the limelight of bad publicity. Leech alert!
#92
Tearing down others is not making you look good here.
Quite frankly you're on thin ice.
#93
And who are you anyway? Rofl |
#94
I stand up for what I believe is right. If this forum wants nothing but sheep following one shepherd, then boot me.
#95
Members with an agenda somehow always find the door. Don't let the door hit you......
#96
Let the record state that I said I quit first....
#97
Great.
Now I'll make it official.
#98
Well that escalated quickly.
Seems like things got a lot more confrontational than they needed to be- by several people. I'll leave it at that.
1966 GTO 1969 Lemans Convertible- F.A.S.T. legal family cruiser. 12.59 on G70-14 Polyglas tires. 1.78 60' 1969 Bonneville Safari- cross country family cruiser. . 1979 Trans Am 400, 4-speed, 4 wheel disc. View from the drivers seat racing down Atco Raceway- http://www.youtube.com/watch?v=GhYDMdOEC7A Ride along in the other lane-http://www.youtube.com/watch?v=mIzgpLtF_uw |
#99
X2.
#100
So .... 068 or 067 ??
Just kidding, now I'm afraid to put any cam in my engine Just for the record ... I've got good info from everyone concerned. I love you all. I enjoy seeing good info from sources both tried and true, and those willing to rock the boat. ALL of you know a lot more than me. I hate to see "topic drift" end up causing problems. |
